21 - 40 of 53 Posts
Discussion starter · #21 ·
How is this thread going to go together in such a way, that someone with a bugeye can find the # for their midpipe to downpipe gasket.
I love the idea, but with cars from 97-15 going in here all over, it's going to get confusing.
Xoxoxoxoxo
Well, the purpose of this thread is not necessarily to give part numbers for all parts and models. Its more just to have the ones we know work on what models all in one place. If someone with a bugeye is looking for that particular gasket and don't see it here then hopefully they will report back here with the number when they find it. That way our list can grow to help further in the future. Also if the part number for something is not here you can tell us what your looking for and maybe we can collectively find it and add it to the list. If all else fails we have Chris also. He can find anything with the last 8 of your vin. ;)
Sent from AutoGuide.com Free App
Discussion starter · #22 ·
tow hook cover 02-07/ front
11+ sedan
Jdm rear fog harness clips and rear fog bolts
Added! Check to make sure I got it right Randy please. I'm not nearly as keen on body stuff as you are so, I could have worded it wrong or something.
dude! awesome!! thanks for this :) EVERYONE!!
i have a few confirmed for 02-03 that arent listed. will get photos and upload them when i can.
i love this as i am an oem part# whore
Discussion starter · #27 ·
I am an oem part # whore as well but unfortunately, for some reason I can no longer edit the original post to add numbers. I've spoke with a mod and admin about this and they don't know why and it looks like it won't be fixed so this thread will probably die a sad death. Too bad cause it had so much potential.
@psinuse: Keith has a part number for an OEM Subaru radiator - that I'm sure at this point he'd like to throw in the trash.
Discussion starter · #29 ·
Maybe we should just turn this into a oem part # request thread since the op can't be edited. I would sure love to know the subaru part # for the 06-07 sti intercooler sprayer nozzels.
i cant confirm the year, but maybe call the dealer and run the part# by them and see what they say?
these are all 100% confirmed for 2002/2003 wrx. received them myself from the dealer for my car. did not see them in master list
FUEL FILTER
42072PA010
GASKET - Y-Pipe to Back of Intercooler
21896AA010
i figure if the OP cant be edited then at least if we keep posting people can just search this specific thread with the search tool. as long as it posted clearly it should work out fine.
Discussion starter · #32 ·
FUEL FILTER
42072PA010
21896AA010
Added those! is the nozzel a windshield washer nozzel, intercooler spray nozzel, or both?
for OE sti Intercooler Sprayer. mounts into the holes in the splitter. still not 100% sure on year but they stock it so i think it is still in use. i would guess 04-12 STI. usually if they keep it in stock it's a part they still currently use (at least at my dealer)
im actually ordering some soon and i will let you know if they fit my V7 STI splitter that is also coming soon
Discussion starter · #34 ·
Added that and sprayer check valve. Put them in the trim, body, exterior section. Wasn't really sure where a good place for them would be. Any suggestions?
SOA has the splitter listed under Body - All Trim Levels, so body seems like a good place for them
also, this can confirm any part #. its what i have been using before i goto the dealer. OEM Subaru Parts Online | Subaru of America
select your model/year/trim and bam! or search by your VIN#
i didnt even know that website existed untill a few weeks ago
Discussion starter · #36 ·
Wow! That is an awesome find @titter ! Every other parts site is not very user friendly. This one is great! Bookmarked fo' sho'!
Gasket - Exhaust Manifold to Head - Confirmed 2002-2005 Naturally aspirated ej engines - L & R are identical
Gasket - Exhaust Manifold to Up Pipe - Confirmed 2002 - 2005 WRX
Gasket - Up Pipe to Turbo Exhaust Side Inlet - Confirmed 2002- 2005 WRX
they could not confirm the nozzle year model but can confirm its a usdm part and it does exist and is a correct part #
they were actually impressed i found such a part #. the guys has been there 10+years and he says he think hes only looked that part up once.
totally going to order some when i upgrade my splitter and i'll repost. but i'll be a while
Discussion starter · #39 ·
I too am trying to piece together intercooler sprayer exactly like the sti one. I have the numbers for the nozzels, check valve, and switch but really need a number for the relay if I can't find one used. I have a used tank & pump and will be looking for the trunk carpet that covers the tank as well.
i did a wiper delete and i use my rear wiper motor and washer tank. i run water in the washer tank in the summer and washer fluid in the winter so it doesnt freeze and pull the rear wiper fuse since you dont need a sprayer in the winter :D the one i made is a copper tube with brass nozzles soldered on and fit into the rubber shroud. but when i upgrade to sti splitter i dont want to cut it up and will try to use the subaru part. you dont really need a check valve, not that much water flows back down the tube, at least on my setup.
+1 wagons!
ya my soldering is crude but im working on that lol
21 - 40 of 53 Posts
