Newbie Need help/suggestion on engine swap
3.1K views 18 replies 5 participants last post by  psinuse
Hi, I recently just purchased a 05 outback xt. It needs a new engine or short block, I've been juggling a few ideas and don't know the best way to go. First would a used sti engine fit and what would I be in for? Or should I go with a sti short block and what would be involved in that?
#5 ·
The difference between the EJ257 and EJ255 is the heads. If you just need the short block, doesn't matter much. I think there might be some small difference I can't remember but it's minor. If you need the heads, stick with the EJ255. Your car is drive by cable, the EJ257 heads are drive by wire. The conversion is a ####tacular amount of work.
