Need help about the Tactrix cable
1.4K views 3 replies 3 participants last post by  lemon19mmm
#2 ·
the flash block (white square) can stay on at all times. you have to position your head in a weird way to be able to find those two green plugs(male/female) and the female or male flash block which should not be hard to find that one.
like i said you can leave the flash block connector on. the two greens are to be plugged only when the software is running and you are trying to retrieve your factory map or flash whatever stage you want. as soon as you are done disconnect them. any other questions dont hesitate to ask.
