Hi all,
It's my first post, but I've been browsing this forum (and many others) for years. I have some questions regarding tires now that I share the enjoyment of having a turbo Subaru (2.5i was my first Subaru).
I have searched around quite extensively, but I have ended up with more questions than answers. Also, most of the threads that I have visited touch on the topic but then quickly stray into aftermarket wheel fitment and tire choices.
I have the stock 8" wide wheels on a 2012 WRX sedan. For reference, the stock tire size is 235/45R17. I'm leaning towards the Michelin Pilot Super Sport tires and the only disadvantage I have found is people saying the sidewalls are a bit more compliant than the OEM Dunlop's.
So here we go:
Should I stick with the OEM tire size or are there enough benefits to going with a wider and/or shorter tire as in a 245/45R17 or 245/40R17 to warrant the change?
Obviously, I understand that a wider tire "should" provide a better contact patch and therefore "better" grip.
From what I've read a shorter tire than OEM (i.e. XXX/40R17) is better for the WRX gearing, but I don't know if this applies to the 08+ models are just the older models. I also admit that I don't understand what "better for gearing" actually means. Also, going from a XXX/45R17 to a XXX/40R17 is a minimal change in height, but I really really want to avoid the "big wheel / small skinny tire" look. I'm not a rapper or a pimp. The ride height is also still stock, so I don't want the wheel and tire to look too small for the wheel well either.
I think the car handles great now for how I drive, it's a daily driver in the Northeast, and I do drive on some pretty bumpy / crappy roads. My main goal was to go a bit wider, but after searching I have so many more questions and concerns that I may just go with the OEM size and be done with it and potentially miss out on some performance advantages.
Would you guys mind sharing your thoughts on this? 235/45R17 (OEM), 245/45R17, or 245/40R17?
So here we go:
