I recently purchased a UTEC Stage 1 and installed the ABC... I turned the boost to match the amount stated in the manual at 4500 RPM. Now everytime I shift from 1-2 and 2-3 and sometimes go TPS% 100 in 3rd I get 1-12 knocks for one logger line before it lows the timing. I have a Perrin CAI, HKS SSQV BOV, and the ABC/UTEC. I was wondering what I should do to remove the knocks, I've always run 93 octane, and in the last tank added an octane boost to try and remove the pre-det. Any advice or help would be greatly appretiated. If you would like you could give me a call at 540/239-2703 (ask for Julian).
-Thanks...
P.S. I've tried lowering the boost to just 14PSI as well as lowered the timing 2-3 through the 3500-5000 range without any luck (the latter of the two removed the knocks from 6-12 to 1-3)...
-Thanks Again!
-Thanks...
-Thanks Again!
