sti tmic with cobb stage 2
12K views 23 replies 9 participants last post by  turmic
im running stage 2 on my car and wondering if i put the sti tmic on it will it be an issue. i just bought a sti top mount for $200 bucks(great shape no dents in the fins) and would like to put it on the car. but if its going to hurt me more than benefit me i wont put it on. im buying pieces at a time for my "build" and going to do all of it at one time but since the tmic is such an easy install just wondering if it would be ok to mount with stage 2.
#4 ·
Yea, gains from a better intercooler are seen via tuning because it will potentially allow you to run more timing/boost. Be are though that STI intercoolers are known for rubbing holes in the firewall AC line. So be careful and see if you can get as much space between the intercooler and that line.
#9 ·
The 02-03 models run pig rich from the factory and also have a greater amount of give than newer models. That's why you can use a MBC with them, albeit not advised without tuning, because the factory tune is a bit more forgiving than the 04 and up.
#6 ·
The only thing it could possibly do from a tuning technical standpoint is slow boost by a microsecond because it is a larger volume intercooler, you might gain .0000001 hp because your intake charge cools by 20 deg or so, which is nothing. Your gains are going to be seen because you can safely add timing and boost without knocking. The intercoolers are post maf, so assuming your maf scaling is correct there shouldn't be any afr issues.
#7 ·
You will be fine. I confirmed this P&L and Cobb. I've been running an STI top mount on my car for over 6 months. My logs look good, no knock at all.
The trick is getting enough air to it. I switched to an STI scoop and splitter. Not sure what options there are for the 02.
That's a great price. I think I have close to $400 into mine b/c I bought a new y-pipe and all new silicone connectors.
#14 ·
they didnt make sti style hood scoops/Splitter for the 02 as a factory option. im pretty sure the bolt pattern is the same or if not its made out of metal i can drill out some new holes to make it work. just wondering if anyone has done this job and what did they use. i was also told i can modify my stock 02 splitter to make the sti tmic work without any fitment issues
