I have a 2012 WRX Limited. I just unhooked my battery to clean the corrosion off the terminals and now my auto up/ down feature on my driver side window isn't working. It still goes up & down, (I have to push the button all the way up or down) just the auto up & down feature stopped working. Any ideas on how to correct this?
I grabbed this from the 2012 owner's manual:
"Initialization of power window
If the vehicle’s battery is disconnected due
to situations such as battery or fuse
replacement, the following functions are
deactivated.
. One-touch auto up/down function
. Anti-entrapment function
Initialize the power window using the
following procedure to reactivate these
functions.
1. Close the driver’s door.
2. Turn the ignition switch to the “ON”
position.
3. Open the driver’s side window halfway
by pushing down the power window
switch.
4. Pull up the power window switch and
close the window completely. Continue
pulling up the switch for approximately 1
second after the window is closed completely."
window wireharness help!
does anyone have a picture of the wire harness that goes to the window (d7). i was installing some speakers and when I pulled on the harness, all the wires came out, about 16-17 of em.
thanks
