1 - 10 of 10 Posts
I've tried using different USB's but the Accessport Manager still won't pick up my Accessport. Anyone else had these issues?
You could contact Cobb and see if they will send you a new cord as well. They should be contacted either way to be made aware of the issue in case it becomes a common problem then they can look into fixing it.
Discussion Starter #4
Yes and it was the cord for me. I used a different one (a PlayStation cord I think) and it worked fine after that. The cord they sent was screwy.
Sent from AutoGuide.com Free App
I tried most of the USB's I have and it won't pick up the Accessport still. I'll try and get Cobb to send me a new one.
I will contact them today to let them know the issues I'm having and see what they say. I will also ask for another cord.
"tried most of the USB's"? You mean you tried diff ports? Do you have a droid charger (micro USB)? Try that cord. Go to device manager on you computer (if you have PC) and see if your USB port has a "?" Mark next to it... Rule out the port that way.
yah bubba is right. its prob not the cord but a "driver software" problem. go into device manager and "scan for hardware changes" with the cord plugged in. you should see a balloon in the lower right that says whether or not the driver loaded or not. if it says cannot load driver i would try reloading the program. maybe the software did not load correctly from the start. what operating system are you using?
Discussion Starter #7
Perfect, I'll give that a shot when I get off work tonight. It's a Nokia charger.
I am running the program on Windows XP. I uninstalled the Manager then installed It again. I'll give that a shot and see what happens.
1 - 10 of 10 Posts
