1 - 18 of 18 Posts
i wouldnt do it. I think the max towing capacity for an outback is 2500lbs and a tribeca 2500lbs IF you have a transmission cooler. I know this is a diff vehicle but thats a LOT of weight to pull with a wrx
what year WRX i can look up the accessory catalog and fine the hitch and see what the weight is recommended from subaru
Discussion Starter #3 (Edited)
It is a 2002 WRX. I have been towing for a while a 2 place snowmobile trailer, but not enclosed. I also tow a Waverunner. It tows EXTREMELY well. It is a manual, so no trans cooler... I just worry about the frontage area of an enclosed trailer.
That looks like a 2 axel balanced on a single axel, personally I wouldn't be comfortable with towing a 2 axle on a WRX. especially one that weighs a thousand pounds without your toys. With a big trailor like that balancing on one axle you are putting alot fo downward stress on your tow package. Not that its a death sentence but its probablly more than your tow kit was designed tt handle. The only recommendation I can make is upgrade those brakes and make sure your rear suspension is up to the task, sagging 12 year old springs and old struts wont like being loaded down like that. Your essentially driving around with double the weight as OEM. I would just be careful and make sure your brakes are up to the task. As for the trans handling the extra weight its not the gears that take most of the stress. Once your in gear the WRX can handle that load no problem but the clutch definitely wasn't built for that.
In most cases its not the trans that causes problems but the nut behind the wheel that makes things go south in a hurry.
Subaru does not even list a trailer hitch to go with the wrx. If it was my car or customer i wouldnt tow anything with it.
Discussion Starter #7
I will say that I have trailered about 1500 lbs with the WRX a decent amount.
It tows that weight with no sweat.
I have seen a few WRX sedans an wagon in the NH area towing pop up campers, boats an such. Exact weight I have no idea
When i went to the subaru accessory catalog, there was no list for a trailer hitch made by subaru. they listed for impreza and outback and legacy, but not wrx. I bet some of our cars could tow a lot of weight. weather or not it is good for the car is a different story. I would NOT tow ANYTHING with it, but to each their own. :)
My 2003 brochure says "towing capacity 2000lbs"
Subaru Impreza Trailer Hitch - 2003 | etrailer.com
That is NOT a factory subaru hitch. I will look again but im almost positive subaru doesn't make one for the wrx. There are hundreds of aftermarket parts for these cars, and hitches are one of them. Just cause some hitch company says its ok doesn't mean it is. It may never cause a problem but as a subaru service advisor i have to go with whats on subarunet.com.
The Subaru part # is,L1010SS000, I looked this up a long time ago. the number might not still be good. But it DID exist. It's for the wagon only because Subaru didn't want to make two versions of it and the people who got the wagon were more likely to tow something. The exhaust on the sedan requires a little different bend to it. Aftermarket to the rescue!
From the 2002/2003 brochure;
<a href="http://s1371.photobucket.com/user/fidrat24/media/IMG_26451_zps9adabd79.jpg.html" target="_blank"><img src="http://i1371.photobucket.com/albums/ag309/fidrat24/IMG_26451_zps9adabd79.jpg" border="0" alt=" photo IMG_26451_zps9adabd79.jpg"/></a>
Note the separate column for the sedan. It IS ok.
From the 2003 Impreza WRX,outback sport accessories brochure;
<a href="http://s1371.photobucket.com/user/fidrat24/media/IMG_26401_zpsa6e5a76d.jpg.html" target="_blank"><img src="http://i1371.photobucket.com/albums/ag309/fidrat24/IMG_26401_zpsa6e5a76d.jpg" border="0" alt=" photo IMG_26401_zpsa6e5a76d.jpg"/></a>
<a href="http://s1371.photobucket.com/user/fidrat24/media/IMG_26441_zps3d4453bb.jpg.html" target="_blank"><img src="http://i1371.photobucket.com/albums/ag309/fidrat24/IMG_26441_zps3d4453bb.jpg" border="0" alt=" photo IMG_26441_zps3d4453bb.jpg"/></a>
<a href="http://s1371.photobucket.com/user/fidrat24/media/IMG_26411_zpsea4d5251.jpg.html" target="_blank"><img src="http://i1371.photobucket.com/albums/ag309/fidrat24/IMG_26411_zpsea4d5251.jpg" border="0" alt=" photo IMG_26411_zpsea4d5251.jpg"/></a>
<a href="http://s1371.photobucket.com/user/fidrat24/media/IMG_26351_zpsfdbe33ac.jpg.html" target="_blank"><img src="http://i1371.photobucket.com/albums/ag309/fidrat24/IMG_26351_zpsfdbe33ac.jpg" border="0" alt=" photo IMG_26351_zpsfdbe33ac.jpg"/></a>
The OP has an 02 WRX. 200lb tongue weight,2000lb towing capacity. Stick to that and Yer good-ta-go!
I found it in the '04 WRX Service Manual in Option Parts. See below.
The Subaru part is a bit stronger with 3 bolts per frame rail that the aftermarket items that have 2 bolts.
I have a Curt hitch for a bicycle rack, but don't intend to tow anything with my thoroughbred performance machine!
Be mindful,Subaru didn't make one for the sedan so if this is a Subaru part then it's for the wagon. Unless of course unless they started making one for the sedan in 04
My thoughts on this is as follows:
The WRX was designed and it's purpose was for road rally.
That said if you want to pull a trailer get a different vehicle.
Why would you want to trash a WRX?
1 - 18 of 18 Posts
