I just bought a 2011 WRX hatch with a blown motor and i cant find anything that makes sense on doing a jdm swap. I am getting alot of conflicting info and the good information i am getting is only for older cars. I m looking into buying a jdm motor and i heard because its a 2.0 not a 2.5 i will need a new ecu and i have also heard the usdm ecu will run the jdm motor fine even though its smaller. Will all the parts off my usdm swap over if i just wanted to to use the jdm longblock? can anyone steer me in the right direction
When you get the 2.0 strip everything off of your 2.5 and put it on the 2.0 just use the 2.0 as a long block basically and it will run like it’s brand new🙂 make sure you use all of your 2.5 sensors.. cam gears.. etc and use your 2.5 wiring harness
