Subaru WRX Fog Light LED Bulbs
Diode Dynamics carries LED bulbs for replacement of your Subaru WRX fog lights, in all major sizes. They are available in HP, XP, and SLF styles. This will make your WRX's fog lights a nice bright white that closely matches factory-equipped HID lighting, and provides additional output! Just simple plug and play, replace the bulb and you are good to go! We also offer Luxeon LED Housings for a complete replacement of your factory fog light housings (2015+ Subaru WRX Model Years)
Diode Dynamics offers the brightest, highest-quality bulbs on the market. Your order will ship same day, and we're here if you need us for support and service. These LED bulb replacements are designed by our engineering team here in St. Louis, and every bulb carries with it a three-year limited warranty.
Brightness:
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb, compared to the factory bulb.
HP48: 265 lumens. Lower brightness than factory, but still provides the crisp white, modern color of LEDs.
XP80: 510 lumens. Similar brightness to factory.
SLF: 850 lumens. Street Legal Output. Much brighter than factory. These are bright! USA Made!
Luxeon LED Replacement Housing: Powered by three genuine Luxeon T LED chips per side, the perfect 5000K white color provides a brilliant LED illumination, with a Trulux measured output of 600 lumens. (Please note: similar styles of lamp can be found online which claim much higher output, but these numbers are highly inflated. These lamps are the brightest on the market!)
Bulb Design
HP48: This bulb is designed with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
Luxeon LED Replacement Housing: Integrated projector lens distributes light in a wide, even pattern, compliant with DOT and ECE standards for use on-road. With a durable poly-carbonate lens, aluminum housing, and constant-current drive circuit, these LEDs will be durable and reliable for years to come.
Included in your order is TWO BULBS (to fit your Subaru WRX).
Diode Dynamics' products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Click below for more info or to order:
Diode Dynamics: Fog Light LEDs for 2008-2014 Subaru WRX
Diode Dynamics: Fog Light LEDs for 2015-2017 Subaru WRX
How to Install 2015-2017 Subaru WRX Fog LEDs | Diode Dynamics
If you have any questions, please don't hesitate to post, PM, email [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
