21 - 24 of 24 Posts
As far as knock goes, are you comparing base and total timing?
No like I said I can't see these very well so I can't look at the map and compare them, but it looks like you have zero's in the feedback knock correction and the fine learning knock correction. You need to open the romraider logs in excel or another spreadsheet program. You won't be able to view them with the program itself.
If you want me to look at the logs better email me the .csv file.
I havent figured out how to view the logs with Rom Raider, so I use Tari to view them...
Romraider logs are viewed the same way as Ecuexplorer,just before you log select a file to log to you can find.The default I believe is the Rom Raider program file.Knock correction vs rpm and IAM are the basic ways of finding knock.The best way is to use a tool found on Rom Raider called "learning view".It automatically will show a 3D map plotting load vs rpm vs FLKC(fine learned knock correction) as well as correction data for fueling.Very,very helpful tuning tool
RomRaider • View topic - Learning View (version 0.4a 10-31-08)
I am in an '09 WRX (not STI) with the cat back exhaust and the downpipe in the mail. The tuner is waiting for me to get over there and have at the beast, but I'm somewhat intimidated by upgrading the BCS. It sounds good and is a cheap & easy mod, but is it really worth it? I'd like to know if it's really safe for the car since I don't race it (yet...) and hear you can pretty much do the same things with the stock BCS. My soon to be tuner is all about the GrimmSpeed EBCS so I got one, but don't know if it's worth installing. Just looking for some confirmation that this is a good thing with a stage 2 exhaust and stock everything else, or do I need a bigger turbo, better intercooler, intake, ect. before this becomes worthwhile for function.
Check your PM's. I sent you a link to an article.
It is worthwhile and easy to do, especially if your tuner likes them. You can do the same things with the stock BCS but aftermarket is better at it.
I DD my STI with a GrimmSpeed BCS. It is safe for the car.
21 - 24 of 24 Posts
