1 - 12 of 12 Posts
Anyone who's installed an oil pressure gauge, what did you use, an oil galley plug or a filter sandwich adapter for you oil pressure sender? The galley plug looks easy, but it shows it replacing a bolt behind the turbo inlet, I thought space might be an issue after the sender is installed there.
EDIT: While we're at it, I have stainless steel fuel lines. I don't know what's involved with a fuel pressure gauge, but I was under the impression it involved t-ing off a fuel line. Is this going to be a problem? Is this true, if so is there a way around it. The web site just says that there is a "sender" included with the pressure gauge, not how or where it connects.
I prefer the sandwich...because most read oil pressure and temp...but yea for a fuel pressure gague all you have to do is tee into a fuel line
Anyone use the galley plug? It's about $30 cheaper than the plate, I'm not planning on doing temp, just pressure.
And what would I do about fuel pressure with steel lines?
I thought I remember reading or hearing about there being an issue or it being a bit harder using one or the other with the 2.5L. I will try and find that info. Just something to think about (maybe).
I used the oil galley plug, but it was too close to the turbo and the heat was killing the oil sender. All I did was got a piece of stainless line about a foot long with a 1\8 npt on one end and a 90 degree 1\8 npt on the other end and relocated it away from the turbo and havent had a problem since.
Discussion Starter #7
Where did you get the npt?( flexible metal tubing I assume?) How much was it? If it's less trouble and money, I might as well get the plate.
There is a shop that makes custom stainless braided lines near my house, and they just crimp a npt fitting on it, it cost like 20 dollars.
I don't know what kind of fittings your fuel rails use, but mcmaster.com has a large variety of fittings that may come in handy. Maybe you could find some sort of tee fitting that would allow you to install the gauge without cutting anything.
Discussion Starter #11
Thanks. I don't really know what I need until I see everything and get my hands dirty. I've got perrin fuel rails and steel lines.
I have a question
I’m new to forums an so I just want to see if I can get a quick answer from knowledgeable Subaru’s guys
My mother’s 06 Subaru Outback 2.5l
The oil pressure sensor fitting is cracked. I completely filled the whole in with in weld with no intention of trying to install the sensor there again
. But since there’s no Sensor
The car is going into “LIMP MODE” because of the relation to the Intake control valve
Can I just Relocate the sensor, To maybe the galley plug
I hope to hear back
1 - 12 of 12 Posts
