1 - 20 of 31 Posts
Just priced out a list of mods, but need a HP ballpark to sell the wife on. Any idea what I can get out of the following? (and what if anything isn't worth buying)
Catback, DP, header, UP, CAI and tuning
The best way to gain HP is a bell-mouth designed downpipe and and tune (COBB AP, pro-tune, ECUtek). What year of the wrx do you have/want? If you have an 06 or newer, you don't need an uppipe since it does not come with a cat in it. 08's and newer would benefit from a CAI but the 02-07's would not. The catback won't give you any gains at all and it is just for the look and sound.
I don't think this type of question is allowed... but if all you need is a number to flaunt to your wife, I'd say ~240 whp assuming you have a 2.0L wrx. It really varies, though. Depending on your car, elevation and type of dyno, my estimate could be way off.
The catback makes a big difference on the 08's, it's not just for sound. I believe the stock 08 piping goes to 1.5" in the middle...
Discussion Starter · #6 ·
Yep, as was said the 08s NEED exhaust work. I have an 08 sedan. DP and catback are nearly minimum. Suby even put a cat in the DP again, so a high flow cat DP is needed IMO. The UP looks restrictive, but I can't find any numbers anywhere on gains with new ones. I probably won't ever look at a new turbo as I leased, and need bolt on mods, not big expensive changes. I can't really find any ballpark gains from anything but flashing and CAI. Subaru performance sells it's own catback which is basically what the 09s get from the factory. (I realize the 09s have a larger turbo, but exhaust was the biggest change otherwise) If I keep it Suby I retain the warranty on the new parts.
Discussion Starter · #8 ·
LOL, even a newbie like me knows not to say that. hehehehe
I think the up pipe is even LESS important that it was on the 02-07 (it wasn't important there either). The turbo placement of the 08 really lends itself to removing restrictions in the headers. No, that's one thing they didn't mess up. Intake, cat back, yes. They did mess those up. The downpipe always had two cats and still does and was always a piece of crap and still is, that never changed.
Discussion Starter · #10 ·
Interesting, so a DP and catback with a flash is probably the best bang for the $. That cuts the cost fairly significantly. I DP listed for the 08 can be had on ebay for $250, but any earlier models go for allot less. I know it's the same engine setup as an 07. Do you know if an early DP fits the 08s?
I've got a local exhaust shop I've worked with for years. I think I'll take a drive and get a CB price from them. Since the car is a lease, I think aluminized is fine for the next 39 months. LOL I'll save the stock setup for trade-in day.
Discussion Starter · #11 ·
There's an 08 STi DP on ebay, and invidia says they take the same aftermarket DP. Would this be a good DP solution to stay legal. What the difference between the STi and the WRK in 08?
Discussion Starter · #14 · (Edited)
I don't mind tweaking a lease (short of stage 3), and I probably will buy if the residual looks decent.
Cobb Intake
Bellmouth Downpipe (catted prob)
Cat Back (whichever brand you like the sound of)
Tune (Cobb AP or something custom)
Voala! Stage 2 WRX v.08
Discussion Starter · #17 ·
Still wondering if a stock STi DP is a viable option that looks stock.
Check Cobbs map notes to see what is required for thier stage 2. They will tell you what it consists of.
Cobb Intake
I have a new 08 WRX, got it on halloween. I've been looking for some upgrades too, specfically, the Cat back exhaust and intake. Most likely intake first, due to the cost, then the Cat back. I'm curious as to whether I should aim for the SPT exhaust or save around three to four hundred dollars and go with a different maker. With the intake, what is the advantage going with a Cobb intake versus another brand?
1 - 20 of 31 Posts
