1 - 20 of 56 Posts
this action is done when you are useing stage 2+ and not reaching your target boost only
DO NOT ADJUST WHILE STOCK OR STAGE 1( it is not needed)
1: Remove C-CLIP from the WG Actuator DO NOT DROP THE C-CLIP
2: Loosen the WG Adjuster nut with 10mm wrench
3: Remove the Adjuster from the WG Flapper by pulling up.
4: Shorten the length of the arm to increase boost, opposite to decrease.
5: Place Adjuster back onto the WG Flapper.
6: Place C-CLIP back onto the locker.
7: Tighten 10mm Adjuster nut to when done
turn only half a turn at a time then check boost
DO NOT ADJUST UNTIL YOU HAVE PROPER EM AND AN ACCURATE WAY TO MONITOR YOUR BOOST!!!!
how mush do you turn.... from stock to make like 16 lbs
STOP RIGHT THERE!!!!!!!
Do you have any EM?
If you do you should either have a boost gauge and/ or a laptop to monitor your settings.
!!!!!!!!!DO NOT ARBITRARILY (sp) TURN YOUR WASTEGATE ARM!!!!!!
Everyone`s "may" be set to different lenghts depending on how it came from the factory.
Thank you and have a nice day.:D
i do have a lab top and i just got the program to monitor my setting.... i also have my new dp pipe on the way.... not planing on doing anything untill after the first when i get home....
1 - 20 of 56 Posts
