2015 WRX/STI Tail as Turn™ +Backup Module
The Diode Dynamics Tail as Turn™ Module + Backup, for the 2015+ WRX or STI! This is a unique mod that was 100% designed by Diode Dynamics in-house, and is manufactured by us right here in St. Louis, Missouri. Made in USA!
The Tail as Turn™ modules will make your nice LED tail light flash as the turn signal as well. With an array of LEDs flashing instead of an amber incandescent bulb, you'll have a unique, modern look!
Then, since your old turn signals are no longer used, you can easily turn them into functional backup lights! You'll drastically increase your visibility.
With the OEM tail light connectors, installation will literally take about 60 seconds, and does not require any wiring at all. I don't think you'll ever find an easier electrical mod! This kit will work with factory or aftermarket tail lights.
The base kit is just $30, which includes a pair of modules with OEM connectors, to convert your LED tail light into the turn signal, with extremely easy installation.
Since you'll be eliminating the factory turn signal bulbs, your vehicle will think the turn signal is out, so you'll need a turn signal flasher module to slow down the hyperblinking. If you already have one, you don't need another. If you don't have one, we offer it with your order for $10.
All kits also come with the extra wire and connector to add backup lights where your old turn signals were, but you do need to run LED bulbs, since you're drawing on the factory backup light circuit. At Diode Dynamics, we also offer the highest-quality LED bulbs on the market, backed by a 3-year limited warranty. For the complete Diode setup, you can add a pair of LEDs to your order, or use any 7440-size white LED.
Your order includes:
(2) Tail as Turn Modules with OEM Plug-and-play Connectors
(1) Power wire to add backup lights
(1) CF18 turn signal flasher (optional, needed to stop hyperblink)
(2) Diode Dynamics LED Bulbs (optional, needed to add backup lights)
CLICK TO VIEW AND ORDER: 2015+ WRX/STI Tail as Turn™ +Backup Module
Remember: at Diode Dynamics, we're here if you need us for support and service, with our award-winning service team. We have been in business for over 8 years. We feature an industry-leading 3-year limited warranty. Something wrong? We ship you the new item with a return label. No waiting around!
Questions? Please feel free to post, PM, call, or email [email protected]
*PM us for the free-shipping code* (U.S. forum members only)
We are an American company, located in St. Louis, Missouri. We are open 9-5 Monday-Friday CST. Give us a call!
Nick C.
Diode Dynamics
(314) 205-3033
