Yesterday I was doing gravel donuts in my 2017 Wrx. My DAM dropped to 0.75 and my FBK and FKL both start to move around when the throttle is about half open. Idle and WOT show no movement and they both stay at 0.
If anyone has any tips please let me know. I am very new to the car scene. Thank you!
Cobb big sf +box, nameless axle back muffler delete, access port v3 Stage 1 + big SF 91 v400 ots tune
Data logs from the drive home:
Time (sec),AF Correction 1 (%),AF Learning 1 (%),AF Sens 1 Ratio (AFR),Accel Position (%),Calculated Load (g/rev),Coolant Temp (F),Dyn Adv Mult (DAM),Feedback Knock (°),Fine Knock Learn (°),Fuel Pressure (psi),Ignition Timing (°),Intake Temp (F),Intake Temp Manifold (F),MAF Volts (V),Oil Temp (F),RPM (RPM),TGV Map Ratio (mult),Throttle Pos (%),Wastegate Duty (%),"AP Info:[AP3-SUB-004 v1.7.4.2-18491][2017 USDM WRX MT COBB Custom Features Gen2][Reflash: Stage1+BigSF 91 v400.ptm - Realtime: Stage1+BigSF 91 v400.ptm]"
0.000,-6.25,-10.16,15.13,7.5,0.31,194,0.750,0.00,0.00,546,25.50,70,84,1.42,175,2323,0.000,11.4,0.00,0 0.034,-5.47,-10.16,15.21,7.5,0.31,194,0.750,0.00,0.00,547,26.00,70,84,1.44,175,2324,0.000,11.4,0.00,0 0.038,-4.69,-10.16,15.22,7.5,0.31,194,0.750,0.00,0.00,556,26.00,70,84,1.50,175,2324,0.000,11.8,0.00,0 0.039,-4.69,-10.16,15.20,7.5,0.31,194,0.750,0.00,0.00,572,26.00,70,84,1.50,175,2322,0.000,11.8,0.00,0 0.041,-4.69,-10.16,15.19,7.5,0.32,194,0.750,0.00,0.00,558,26.00,70,84,1.50,175,2321,0.000,11.8,0.00,0 0.063,-4.69,-10.16,15.25,7.5,0.32,194,0.750,0.00,0.00,577,26.00,70,84,1.50,175,2321,0.000,11.8,0.00,0 0.067,-4.69,-10.16,15.27,7.5,0.32,194,0.750,0.00,0.00,555,25.50,70,84,1.52,175,2318,0.000,11.4,0.00,0 0.070,-4.69,-10.16,15.30,7.5,0.32,194,0.750,0.00,0.00,570,25.50,70,84,1.52,175,2314,0.000,11.4,0.00,0 0.072,-4.69,-10.16,15.36,7.5,0.32,194,0.750,0.00,0.00,579,25.50,70,84,1.52,175,2312,0.000,11.4,0.00,0 0.106,-3.91,-10.16,15.37,7.8,0.32,194,0.750,0.00,0.00,594,25.50,70,84,1.54,175,2306,0.000,11.4,0.00,0 0.108,-3.91,-10.16,15.43,8.2,0.32,194,0.750,0.00,0.00,581,25.50,70,84,1.46,175,2300,0.000,11.8,0.00,0 0.113,-3.91,-10.16,15.45,8.6,0.32,194,0.750,0.00,0.00,561,25.50,70,84,1.46,175,2299,0.000,11.8,0.00,0 0.115,-3.91,-10.16,15.47,8.6,0.32,194,0.750,0.00,0.00,577,25.50,70,84,1.46,175,2299,0.000,11.8,0.00,0 0.116,-3.91,-10.16,15.49,8.6,0.32,194,0.750,0.00,0.00,565,25.50,70,84,1.54,175,2298,0.000,12.6,0.00,0 0.118,-3.12,-10.16,15.46,9.0,0.34,194,0.750,0.00,0.00,567,25.00,70,84,1.54,175,2298,0.000,13.0,0.00,0 0.120,-3.12,-10.16,15.41,9.0,0.34,194,0.750,0.00,0.00,589,25.00,70,84,1.54,175,2298,0.000,13.0,0.00,0 0.121,-3.12,-10.16,15.39,9.0,0.35,194,0.750,0.00,0.00,582,25.00,70,84,1.56,175,2302,0.000,13.8,0.00,0 0.143,-3.12,-10.16,15.43,9.0,0.35,194,0.750,0.00,0.00,561,25.00,70,84,1.56,175,2302,0.000,13.8,0.00,0 0.145,-3.12,-10.16,15.44,10.2,0.36,194,0.750,0.00,0.00,568,25.00,70,84,1.56,175,2308,0.000,13.8,0.00,0 0.147,-3.12,-10.16,15.44,10.2,0.36,194,0.750,0.00,0.00,598,25.00,70,84,1.56,175,2308,0.000,13.8,0.00,0 0.151,-3.12,-10.16,15.40,11.4,0.37,194,0.750,0.00,0.00,576,23.50,70,84,1.62,175,2315,0.000,14.2,0.00,0 0.154,-3.12,-10.16,15.37,12.5,0.37,194,0.750,0.00,0.00,630,23.50,70,84,1.62,175,2321,0.000,14.2,0.00,0 0.156,-3.12,-10.16,15.32,12.9,0.40,194,0.750,0.00,0.00,635,23.50,70,84,1.64,175,2331,0.000,15.4,0.00,0 0.199,-3.12,-10.16,15.27,12.9,0.44,194,0.750,0.00,0.00,677,22.50,70,84,1.68,175,2344,0.000,16.1,0.00,0 0.211,-2.34,-10.16,15.24,12.9,0.45,194,0.750,0.00,0.00,726,21.50,70,84,1.76,175,2346,0.000,16.9,0.00,0 0.223,-2.34,-10.16,15.24,12.9,0.47,194,0.750,0.00,0.00,755,21.50,70,84,1.76,175,2349,0.000,16.9,0.00,0 0.238,-2.34,-10.16,15.19,12.9,0.48,194,0.750,0.00,0.00,720,21.50,70,84,1.76,175,2351,0.000,16.9,0.00,0 0.251,-2.34,-10.16,15.15,12.9,0.48,194,0.750,0.00,0.00,765,21.50,70,84,1.76,175,2351,0.000,16.9,0.00,0 0.263,-3.12,-10.16,15.16,12.9,0.50,194,0.750,0.00,0.00,810,20.00,70,84,1.84,175,2359,0.000,17.3,0.00,0 0.295,-3.12,-10.16,15.00,12.9,0.52,194,0.750,0.00,0.00,820,19.00,70,84,1.86,175,2367,0.000,16.9,0.00,0 0.326,-3.12,-10.16,14.97,12.5,0.52,194,0.750,0.00,0.00,886,19.00,70,84,1.86,175,2371,0.000,16.9,0.00,0 0.339,-3.12,-10.16,14.92,12.5,0.53,194,0.750,0.00,0.00,931,19.50,70,84,1.84,175,2375,0.000,16.9,0.00,0 0.355,-3.12,-10.16,14.91,12.5,0.53,194,0.750,0.00,0.00,953,19.50,70,84,1.84,175,2378,0.000,16.9,0.00,0 0.367,-3.12,-10.16,14.85,12.2,0.53,194,0.750,0.00,0.00,974,19.50,70,84,1.76,175,2383,0.000,16.9,0.00,0 0.379,-3.12,-10.16,14.80,12.2,0.53,194,0.750,0.00,0.00,954,19.50,70,84,1.76,175,2382,0.000,16.9,0.00,0 0.404,-3.12,-10.16,14.75,12.2,0.53,194,0.750,0.00,0.00,977,19.50,70,84,1.76,175,2386,0.000,16.9,0.00,0 0.416,-3.91,-10.16,14.73,12.2,0.53,194,0.750,0.00,0.00,950,19.50,70,84,1.76,175,2388,0.000,16.9,0.00,0 0.418,-3.91,-10.16,14.71,12.2,0.53,194,0.750,0.00,0.00,985,19.50,70,84,1.76,175,2390,0.000,16.9,0.00,0 0.430,-3.91,-10.16,14.71,12.2,0.53,194,0.750,0.00,0.00,970,19.50,70,84,1.76,175,2390,0.000,16.9,0.00,0 0.442,-3.91,-10.16,14.73,12.2,0.53,194,0.750,0.00,0.00,983,19.50,70,84,1.76,175,2394,0.000,16.9,0.00,0 0.473,-3.91,-10.16,14.75,12.2,0.53,194,0.750,0.00,0.00,982,19.50,70,84,1.74,175,2394,0.000,16.9,0.00,0 0.475,-3.91,-10.16,14.78,12.2,0.53,194,0.750,0.00,0.00,1001,19.50,70,84,1.74,175,2395,0.000,16.9,0.00,0 0.487,-3.12,-10.16,14.90,12.2,0.53,194,0.750,0.00,0.00,976,19.50,70,84,1.80,175,2401,0.000,16.9,0.00,0 0.499,-3.12,-10.16,14.92,12.2,0.53,194,0.750,0.00,0.00,1001,19.50,70,84,1.80,175,2403,0.000,16.9,0.00,0 0.582,-3.12,-10.16,14.96,12.2,0.53,194,0.750,0.00,0.00,963,19.50,70,84,1.80,175,2406,0.000,16.9,0.00,0 0.614,-2.34,-10.16,15.26,12.5,0.53,194,0.750,0.00,0.00,1036,20.00,70,84,1.82,176,2421,0.000,17.3,0.00,0 0.616,-0.78,-10.16,15.39,12.5,0.53,194,0.750,0.00,0.00,998,20.00,70,84,1.84,176,2440,0.000,17.3,0.00,0 0.621,0.00,-10.16,15.41,12.5,0.53,194,0.750,0.00,0.00,1017,20.00,70,84,1.84,176,2452,0.000,17.3,0.00,0 0.633,0.00,-10.16,15.37,12.5,0.53,194,0.750,0.00,0.00,1047,20.00,70,84,1.84,176,2461,0.000,17.3,0.00,0 0.636,0.00,-10.16,15.35,12.5,0.53,194,0.750,0.00,0.00,1096,20.00,70,84,1.84,176,2462,0.000,17.3,0.00,0 0.655,0.00,-10.16,15.34,12.9,0.53,194,0.750,0.00,0.00,1076,20.00,70,84,1.84,176,2471,0.000,17.3,0.00,0 0.667,0.00,-10.16,15.34,12.5,0.53,194,0.750,0.00,0.00,1105,20.00,70,84,1.80,176,2477,0.000,17.3,0.00,0 0.679,0.00,-10.16,15.36,12.5,0.53,194,0.750,0.00,0.00,1090,20.00,70,84,1.80,176,2493,0.000,17.3,0.00,0 0.681,0.00,-10.16,15.34,12.5,0.53,194,0.750,0.00,0.00,1099,20.00,70,84,1.80,176,2499,0.000,17.3,0.00,0 0.714,0.00,-10.16,15.15,12.5,0.53,194,0.750,0.00,0.00,1129,20.00,70,84,1.82,176,2515,0.000,17.3,0.00,0 0.726,0.00,-10.16,15.10,12.5,0.53,194,0.750,0.00,0.00,1092,20.00,70,84,1.82,176,2519,0.000,17.3,0.00,0 0.747,0.00,-10.16,15.06,12.5,0.53,194,0.750,0.00,0.00,1073,20.00,70,84,1.82,176,2528,0.000,17.3,0.00,0 0.759,0.00,-10.16,15.06,12.5,0.53,194,0.750,0.00,0.00,1143,20.00,70,84,1.82,176,2532,0.000,17.3,0.00,0
