Well, here's a good reason to not close your trunk with your wing. It can eventually stress it out and break one of the mounting holes. Since there are only 4, using the remaining ones to secure the wing is pretty risky on not letting water enter your trunk. There is no way to fix the problem since it's molded into the wing. And paying +$350 for a new spoiler just seems ridiculous.
Here's my solution. Dry wall anchors.
Put the spoiler on, loosely start screwing on a pair on nuts on the non- damaged side. Then lift up on the other side so you can stick the dry wall screw thru the trunk from the inside. Screw on the anchor as much as you can. Then push the anchor into the damaged hole of the spoiler. You can't do it with the spoiler mounted because the screw hole for the trunk is too small.
