This winter, the guys over at MagnaFlow have extended their line-up of fully-configurable xMOD Series exhaust systems. Their latest application-specific option is engineered for a 2018-2020 Subaru WRX. It is a dyno-proven, multi-metal construction manufactured from top-quality materials with all the specifications of your WRX in mind.
Each system comes equipped with straight-through mufflers, fast-flowing mandrel bent pipes, and race-bred V-Band clamps allowing you to switch from moderate exhaust notes to the wild sounds of the xMOD xTreme Deletes.
MagnaFlow - Subaru xMOD Series Cat-Back Performance Exhaust System
Fits: 2018-2020 Subaru WRX
Notes: While xMOD systems are 100% emissions legal, the use of xTreme Deletes is recommended for track use only. Check local noise regulations for street legality.
Specifications:
Check out this page to read more about the new MagnaFlow Exhaust System.
Specifications:
- Type Cat-Back
- Series xMOD
- Main Piping Diameter 3"
- Exit Style Single Straight Driver Side Rear
- Inlet Connection Type Bolt-On
- Muffler Quantity 4
- Muffler Finish Polished
- Tip Type Welded-On;Double Wall;Angle Cut;Rolled Edge
- Tip Shape Round
- Tip Material Carbon Fiber
- Tip Finish Carbon Fiber
- Tip Diameter 4.625"
- Tip Length 6"
