For sale is my 2014 STI w/ 43k miles. It has an IAG Stage II Tuff block with 10,500 miles (fully built/assembled by IAG Performance).
It has around 330WHP & 400lb-ft on E-85. It has a flex fuel kit and is tuned for premium and E-85.
The rest of the mods are below. This car is ****ing awesome. Just had a full detail/wax. There is a small scratch on one wheel and a small chip out of one of the fender flares. Both are pictured below.
Selling for $39,000.
Engine Modifications:
IAG Stage 2 Tuff Block (Fully Built & Assembled by IAG Performance) Engine has 10k miles
Tuned by Cleo @IAG Performance in Westminster, MD (E85 & Premium)
Flex Fuel Kit
Upgraded heavy duty clutch
Greddy EVO 3 cat-back exhaust
Cobb downpipe (no catalytic converter)
IAG TGV deletes
Cosworth thermal intake manifold gaskets
IAG fuel rail system
IAG fuel lines
Fuel Injector Clinic 1200cc injectors
Cobb EBCS
Cobb SF intake airbox assembly
Perrin turbo inlet
Cobb crank pulley
Walbro fuel pump
Killer B Holy Header
Killer B Up-pipe
Greddy magnetic drain plug
Cobb V3 Accessport
Suspension Modifications:
Ohlin Road & Track Coilover suspension
Perrin front/rear spacers 10mm/15mm
Cusco rear lower control arms (fully adjustable)
Cusco rear trailing arms (fully adjustable)
Whiteline rear toe arms (fully adjustable)
GT Spec rear subframe/lower control arm braces
Whiteline Anti Lift Kit (Front)
Super Pro Roll Center kit (fully adjustable)
Whiteline Camber bolts
Whiteline Rear Camber adjustment bushings (kit)
Eibach 25mm front sway bar
Eibach 22mm rear sway bar
Kartboy rear sway bar endlinks
Cusco front sway bar endlinks
Whiteline steering rack bushings (kit)
Cusco power steering rack brace
Cusco rear OS upper strut bar
Whiteline rear Positive Traction kit
Whiteline rear subframe lockdown bushings
Cusco rear member braces
Whiteline inner control arm bushings (kit)
Whiteline rear differential positive power kit
Cusco front lower arm brace
Cusco front lower control arm braces
Cusco crossmember power brace
Cusco rear lower power brace
Whiteline rear upper control arm bushings (kit)
Cusco front member reinforcement power brace
Whiteline full drivetrain bushing kit
Drivetrain Modifications:
DSS Carbon Fiber drive shaft (1 piece)
STi Group N Engine Mounts
STi Group N pitch stop mounts
Beatrush lower transmission mount
Beatrush propeller mount bushings
Whiteline Gearbox positive power bushings
Wheels/Tires/Brakes:
Work Meister S1 3 Piece wheels (anodized copper, matte black face, white WORK lettering, matte black hardware, Work valve stems)
18x10 +30 front, +31 rear
O-Disk
Bridgestone Potenza S-04 Pole Position 285/35/18 front/rear
Full Ceramic Pro 9h treatment
Project KICS black lugnuts
DBA 400 front/rear rotors
Stop Tech stainless steel brake lines
Exterior:
HT Auto's fender flares
Custom carbon fiber rocker panel extensions
Custom carbon fiber front bumper canards
APR front splitter
Shaved front bumper
IPF JDM blue fog lights
Custom headlight housings with LED corner light upgrade
APR carbon fiber side mirrors
Subaru window visor extensions
Perrin shorty antenna
JDM third brake light
Valenti full LED taillight conversion
Shaved trunk/decklid
STi S207 side badges
Interior:
Sunroof
Subaru Navigation
Sparco JDM R333 seats (Black Japan edition)
Sparco seat sliders
Sparco seat brackets
Perrin DCCD knob
TWM custom weighted shift knob
Cobb short shifter
Cobb shifter bushings
Keys Racing suede steering wheel
Works Bell Hub w/up assembly
JDM STi push button start
Bear Lock gear lock (added security)
JL Audio W7 8" subwoofer
Alpine Type R front components
Alpine Type R rear speakers
JL Audio 4 channel amp
Weather Tech floor mats
Flex Fuel Kit
IAG TGV deletes
IAG fuel lines
Cobb EBCS
Perrin turbo inlet
Cobb crank pulley
Walbro fuel pump
Killer B Up-pipe
Cobb V3 Accessport
O-Disk
Exterior:
APR front splitter
Shaved front bumper
Interior:
Sunroof
Subaru Navigation
Sparco seat sliders
Perrin DCCD knob
Cobb short shifter
