Oil smoke..
smokes at Idle after driving..
Smokes in between shifts..
Does not smoke while cruising..
Does not smoke under power or at WOT..
Runs amazing, makes boost great, compression test is good, doesn’t seem to have excessive blowby..
It’s probably the turbo and I should start checking the boost pipes and down pipe for oil I imagine..
It has a VF48 and has anti lag/2 step rev limiter..
AND it seems like the FORGE bypass valve isn’t working or is set way too tight because it has a TON of comp surge between shifts or even letting off the throttle from light cruising..
Sounds like conditions extremely hard on a turbo to me..
Are these sounding like typical smoke symptoms of a failing turbo?
