Non Start 2006 WRX Limited - Subaru WRX Forum
User Tag List
 2Likes
post #1 of 22 Old 09-03-2019, 11:00 AM Thread Starter
So I drove from my lawyer's office to my home no issues. Started my car to drive back had a slightly rough idle but I just thought it might be a gas issue and was going to throw some gas treatment in the tank then top off with some other gas after I went back to my lawyer. Went to my lawyer's office came back to my car and it wouldn't start. Called my mechanic and he said it sounds like a battery issue. Replaced the battery and the car still wont fire up. Any ideas?
Joseph conti is offline
post #2 of 22 Old 09-03-2019, 12:09 PM
could be a lot of things "won't start" is pretty vague...
If it's getting power, is the starter motor spinning? If not, maybe starter motor or solenoid. If that turns the engine but it doesn't fire, could be a fuel issue. Check plugs, wires, fuel pump, etc.
If nothing is happening, check fuses.
- d4c
2007 WRX wagon 5MT
stock (for now)
daddy4count is offline
post #3 of 22 Old 09-03-2019, 12:24 PM Thread Starter
So all of the electronics come on the starter spins but the motor doesn't run. Sorry I should have been more specific when saying wont start.
post #4 of 22 Old 09-03-2019, 12:28 PM
You're getting electricity, that's half the battle.
The other half is fuel.
If the starter motor is spinning, but nothing fires... start with plugs/coil packs and then fuel lines / pump?
Also, check your fuses anyway... sucks to spend days looking for a problem when it turns out to be a 50 cent fuse.
- d4c
2007 WRX wagon 5MT
stock (for now)
post #5 of 22 Old 09-03-2019, 12:48 PM Thread Starter
thanks
post #6 of 22 Old 09-03-2019, 04:40 PM Thread Starter
Timing Belt issue a cogged pulley fell apart
daddy4count likes this.
post #7 of 22 Old 09-04-2019, 10:36 AM
Zoinks!
- d4c
2007 WRX wagon 5MT
stock (for now)
post #8 of 22 Old 09-04-2019, 10:50 AM Thread Starter
Daddy4count you liked this?
post #9 of 22 Old 09-05-2019, 09:48 AM
I liked that you figured it out. Not that it happened.
- d4c
2007 WRX wagon 5MT
stock (for now)
post #10 of 22 Old 09-05-2019, 09:55 AM Thread Starter
Ok thanks. Hope it turns out better than what is prognosed
post #11 of 22 Old 09-09-2019, 02:31 PM Thread Starter
2300 for a valve job
post #12 of 22 Old 09-10-2019, 12:09 PM
Holy shit balls!!
- d4c
2007 WRX wagon 5MT
stock (for now)
post #13 of 22 Old 09-10-2019, 02:41 PM Thread Starter
Holy shit balls!!
that expensive?
post #14 of 22 Old 09-10-2019, 02:49 PM
Honestly couldn't say for sure... but I feel like you could get brand new heads for that price?
I have not had it done on my WRX... My outback Heads/Valves were under $1,000 to rebuild.
Depending on where you are and what's involved that may not be too terrible... but I would get a couple other quotes to be safe.
- d4c
2007 WRX wagon 5MT
stock (for now)
post #15 of 22 Old 09-10-2019, 03:46 PM Thread Starter
Well the water pump, timing belt, and pulleys are included. I got another quote as my car sat in pieces as I just found another good subie mechanic and they wanted 300 less. Alas my car already sits in pieces at the place it was at so Im just gonna pay the 2300 then if I have another repair in the future hopefully not Ill try that other place
