VF39 install help - Subaru WRX Forum
post #1 of 9 Old 02-25-2009, 11:22 AM Thread Starter
07EJ25Ltd's Avatar
07EJ25Ltd is an unknown
VF39 install help
hey everyone, im getting ready to swap out my turbo for a vf39 and im looking for anyone in the CT area to give me a hand with the install.
subarus do it horizantal
07EJ25Ltd is offline
post #2 of 9 Old 02-25-2009, 06:18 PM
VD5505's Avatar
do you have the stock up pipe still? what other mods is done to that car
VD5505 is offline
post #3 of 9 Old 02-25-2009, 06:25 PM
He has an 07 WRX. His stock up-pipe is catless.
post #4 of 9 Old 02-25-2009, 06:48 PM
VD5505's Avatar
dang i didnt even notice it was 07 my bad lol
VD5505 is offline
post #5 of 9 Old 02-25-2009, 06:58 PM Thread Starter
07EJ25Ltd's Avatar
I have an accessport, tbe+sti tmic and the vf39 are on the way, along with a walbro 255 and some gaskets (uppipe to turbo and turbo to downpipe). Anything else I might want to order from the dealer like oil lines or anything for the turbo?
post #6 of 9 Old 02-25-2009, 07:45 PM
boo-key's Avatar
I belive you will need a oil return line if your vf39 did not come with one.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #7 of 9 Old 02-25-2009, 07:58 PM
04paulieWRX's Avatar
04paulieWRX is an unknown
potentially boost control solenoid or turbo inlet
04paulieWRX is offline
post #8 of 9 Old 02-25-2009, 08:20 PM
Bootsie's Avatar
Bootsie is an unknown
I would say a boost control solenoid also. Im not sure if the newer wrx solenoids are as bad as mine but i got stuck at 16psi becasue of it. Unless you dont plan on running that much boost... Good luck!
Bootsie is offline
post #9 of 9 Old 02-26-2009, 02:47 AM
Look, you can't use an aftermarket BCS with the cobb map. If you're getting a custom tune, that's different.
