Thermal Phenolic Intake Gaskets for Subaru
The Gizzmo Thermal Gasket is a thick 'Phenolic' inlet manifold gasket that acts as a barrier stopping heat transferring from the engine block through into the inlet manifold. Stopping this heat transfer results in a cooler inlet charge temperature and in doing so increases engine power in much the same way an intercooler does, except this is able to benefit a turbo and non-turbo setup.
Key benefits of using the Gizzmo Phenolic Thermal Intake Gasket: Produces a cooler intake manifold and intake charge resulting in MORE POWER Almost invisible modification, looks stock for the stealth factor Better gas mileage Replaces stock gaskets Reusable over and over No undesirable side effects
Cheers,
Lloyd
www.GizzmoUSA.com
