Go Back   WRX Forums > General > Vendor Announcements
Old 03-16-2008, 12:17 AM   #1 (permalink)
WRXtuners Supporting Vendor
TunerTools's Avatar
Car: 2004 SSR
Reputation: TunerTools is an unknown
Send a message via AIM to TunerTools
Thermal Phenolic Intake Gaskets for Subaru
The effects of colder intake air don't always come from cold air intakes!
Cooler Air = More Horsepower & Better Mileage
by Gizzmo Electronics are now in stock
See the review by AutoSpeed Magazine of the
Gizzmo Thermal Intake Gaskets
Now Available at:
TunerTools.com
and
GizzmoUSA.com
Subaru EJ20 '98o n/EJ25WRX/STI/Outback
Subaru EJ20 up to '98WRX/STI
The Gizzmo Thermal Gasket is a thick 'Phenolic' inlet manifold gasket that acts as a barrier stopping heat transferring from the engine block through into the inlet manifold. Stopping this heat transfer results in a cooler inlet charge temperature and in doing so increases engine power in much the same way an intercooler does, except this is able to benefit a turbo and non-turbo setup.
Key benefits of using the Gizzmo Phenolic Thermal Intake Gasket:
  • Produces a cooler intake manifold and intake charge resulting in MORE POWER
  • Almost invisible modification, looks stock for the stealth factor
  • Better gas mileage
  • Replaces stock gaskets
  • Reusable over and over
  • No undesirable side effects
Cheers,
Lloyd
www.GizzmoUSA.com
