-   Vendor Announcements (http://www.wrxtuners.com/forums/f85/)
-   -   STi Suspension Components @ EDO Performance (http://www.wrxtuners.com/forums/f85/sti-suspension-components-edo-performance-12679/)
Edo Performance 06-12-2006 04:42 PM
[COLOR=Magenta][B][SIZE=3]STi front strut bar Legacy GT/Wagon [/SIZE][/B][/COLOR] - [B]Price: $255[/B]
STi Strutbars are designed to improve chassis rigidity and reduce flex. The strutbar is made of an aluminum tube shaft, high strength and rigidity are obtained without unnecessary weight gain.
[IMG]http://www.edoperformance.com/ForumImages/NASIOC/Classified/LGTstrutbar.jpg[/IMG]
[B][SIZE=3][COLOR=Magenta]STi Rear Link Set (Full Pillowball) - 02+ WRX[/COLOR][/SIZE][/B] - [B]Price: $525.00[/B]
The four piece STi lateral link set upgrades 6 of the link bushings to pillow ball type joints and the remaining 2 bushings (rear outer bushings) to STi group N hardened bushings. For use with stock pyro-ball swaybar links as on the MY04 STi. 6-pc. set can be used on MY04 STi but requires changing rear swaybar to non-STi version
[IMG]http://shop.edoperformance.com/images/STi/STI_Lateral_Links%20copy.jpg[/IMG]
[COLOR=Magenta][B][SIZE=3]STi Rear Link Set - 04+ STI [/SIZE][/B][/COLOR] - [B]Price: $350.00[/B]
Features improved bushings to eliminate all compliance and ensure smooth articulation of the suspension. Tightens up the handling and improves suspension feedback to give the driver full confidence while driving at the limit. Impreza set is 6 pieces and includes swaybar link kit. Forester set is 4 pieces and uses original swaybar links. Impreza version pictured.
[IMG]http://www.edoperformance.com/ForumImages/NASIOC/Classified/linkc.jpg[/IMG]
[COLOR=Magenta][SIZE=3][B]STi Rear Link Set (Full Pillowball) - 05 STi[/B][/SIZE][/COLOR] - [B]Price: $575.00[/B]
[IMG]http://www.edoperformance.com/ForumImages/NASIOC/Classified/05_latlinks.jpg[/IMG]
[B][SIZE=3][COLOR=Magenta]STi Rear Trailing Arm Set - 02+ WRX/STI[/COLOR][/SIZE][/B] - [B]Price: $275.00[/B]
STi pillow ball trailing link set reduces dynamic toe changes and significantly improves the handling.
[IMG]http://shop.edoperformance.com/images/STi/STi_Trailing_Arm%20copy.jpg[/IMG]
[SIZE=3][COLOR=Magenta][B]STi Pink Spring Set - Legacy GT[/B][/COLOR][/SIZE] - [B]Price: $379[/B]
STi lowering spring set reduces the vehicle's center of gravity for improved handling characteristics while still maintaining reasonably good ride comfort. Excellent for fast road and mild competition use. Can be used with factory struts, or more effectively with STi factory or sport adjustable strut set.
[IMG]http://www.edoperformance.com/ForumImages/NASIOC/Classified/STiPinkSprings.jpg[/IMG]
[B][SIZE=3][COLOR=Magenta]STi Pink Spring Set - 02-03 WRX [/COLOR] [/SIZE] [/B] - [B]Price: $379[/B]
[COLOR=Magenta][B][SIZE=3]STi Pink Spring Set - 04+ WRX/STI[/SIZE][/B][/COLOR] - [B]Price: $379[/B]
[COLOR=Magenta][B][SIZE=3]STi Pink Spring Set - 2004-2005 Forester XT[/SIZE] [/B][/COLOR] - [B]Price: $379[/B]
-kev.
[url]www.edoperformance.com[/url]
[email]kevin@edoperformance.com[/email]
512-462-0125 x21
