Power Enterprise Injector Set - Subaru WRX Forum
post #1 of 1 Old 09-23-2004, 11:07 AM Thread Starter
US$$100.80
Many engine fuel systems are electrically controlled. Multi Point Injection (MPI) system, for example, has injectors installed in each cylinder.
We offer two kinds of injectors, "top feed" and "side feed (bottom feed)" (cf. fig. 1). The number of injector nozzles depends on the specification of the engine.
DOHC 4 valve engine has two intake ports and often takes two injector nozzles. The reason is to avoid incomplete combustion caused by fuel mist hitting and crushing onto the wall of a intake port and flowing in drops.
The injector basically sprays fuel (150-200 microns) on the back of a valve head preventing fuel mist from hitting against the wall of any intake port (cf. fig. 2).
We designed and developed injectors for RB26 (normal one has one intake port.), 1JZ and 2JZ. Power Enterprise big capacity injectors realize not only high power output but also improved response time and cleaning of exhaust gas.
Direct product link with figures HERE
Call in 512-462-0125 or mail gwen@edoperformance.com orPM me. Mention wrxtuners.net when contacting us. Reasonable negotiation welcome !
Edo Performance is offline
