More Lighting for Less! HID Xenon Kits starting at $34.95 - Page 2 - Subaru WRX Forum
Closed Thread
post #16 of 36 Old 08-10-2010, 09:33 PM
it's the shaping of the mirrors to properly focus the light beam, the HID bulbs will fit into and work in your lamp, but there will just be increased glare and they won't have the proper cutoff
post #17 of 36 Old 08-10-2010, 09:38 PM
WRXnewB is an unknown
Okay, good to know. I was going to wait until I got some projector headlights anyway.
WRXnewB is offline
post #18 of 36 Old 08-11-2010, 12:47 AM
Originally Posted by WRXnewB View Post
The headlights I want to get are here.
2004-2005 Subaru Impreza WRX LED Halo Projector Headlights | Turbo Metal Reviews
These would work with the HID conversions though, correct?
No, they won't. Those are still halogen optics. And they are bad ones at that. I've previously dissected them with pictures but at the moment don't feel like looking them up. They use narrow beam optics (bad for low beams), have an extremely awkward cutoff, don't produce even light distribution (hit and cold spots), and produce glare with HIDs. As I previously stated, retrofits and STI headlamps are the only options you have.
And no offense, but those are not the most aesthetically pleasing option you could have selected. The people that tend to buy things like those tend to...well....
Originally Posted by basco View Post
Uhh YOUR wrong, in order to use HIDs all one would need is this DDM Slim HID Kits (35w & 55w) but in order for them to function to their full capability you would then need to retrofit proper optics IE 04-05 STi Headlamps
No offense, but you're arguing with someone with a high level of understanding in the lighting department. The fact that they will physically fit has nothing to do with the fact that they cannot and should not be installed without the proper optics. My suggested is to discontinue advising others to use HID kits. You're doing a great disservice.
post #19 of 36 Old 09-23-2010, 08:38 PM
javedjee77 is an unknown
Air Check Valve
im new here but i have the same problem on my celica gts took it to the mechanic and told me wheel balancing is required could be the same
javedjee77 is offline
post #20 of 36 Old 09-30-2010, 11:27 PM
Trevvrx is an unknown
I have a bug eye when I bought it it had morrette heads and tails shortly after I tried a few aftermarket set ups but eventually went back to stalk lights then I bought a HID kit, I will admit the stock headlights are not the best for HID's like it was said before they don't focus the light properly and had almost no cut off. I was constantly getting flashed by oncoming traffic. so I went back to the morrette's which are projectors they are amazing. I did get a huge benefit with my stock headlights but at a cost to other drivers and those benefits were realized ten fold once I put in the morrettes. You can buy a cheap set of projectors on ebay that would work fine but if you buy an HID kit and you buy those headlamps you'll need to buy H7 bulbs instead. If your curious as to how I know this I bought them haha.
Trevvrx is offline
post #21 of 36 Old 10-01-2010, 01:10 AM
I used to have HIDs in my old Morettes. The results are absolutely terrible because they bring out their horrid optic designs. You have ECE regulations to thank for that. And you still have issues with the fact that the Valeo optics in those lights still can't focus HIDs correctly because they were not designed for them. In other words, you can't HIDs in Morettes either.
post #22 of 36 Old 10-01-2010, 09:19 AM
huh mine look great they don't blind on coming drivers and there are no hot and cold spots, the cut off is nice. all the problems I had with my stock headlights went away when I put the morrettes on.
Trevvrx is offline
post #23 of 36 Old 11-13-2010, 03:35 PM
herms_blu_beauty is an unknown
so what exactly would i need for a 2002 wrx to convert to hid?
herms_blu_beauty is offline
post #24 of 36 Old 11-14-2010, 02:39 AM
A retrofit using true HID optics.
post #25 of 36 Old 11-14-2010, 10:23 PM
EvansWagon is an unknown
yes that would work but because his headlights are halogen to proper run hids he would need to install hid projectors i.e such as D2S because they project the light properly and provid the correct cut off.
so you need HID projectors or HID reflective houseing you can check out Lightwerks if you want to learn more about it they are a projector retrofit service
EvansWagon is offline
post #26 of 36 Old 11-15-2010, 04:59 PM
ScoobNJ is an unknown
I feel like I'm in the twilight zone, this thread has to be a joke.
ScoobNJ is offline
post #27 of 36 Old 11-15-2010, 05:02 PM
Jchon3 is an unknown
ermmm i have no idea which kit i need....
i have a 11 WRX and im kinda new to this stuff so. some help please?
Jchon3 is offline
post #28 of 36 Old 11-15-2010, 11:35 PM
You need 2011 WRX Premium or STI headlights first.
post #29 of 36 Old 11-17-2010, 09:38 PM
mfarnham's Avatar
mfarnham is an unknown
What exactly do I need to order to convert my 06 WRX to HID's?
mfarnham is offline
post #30 of 36 Old 11-18-2010, 06:29 AM
STi or WRX Premium headlamp assemblies
Closed Thread
