Go Back   WRX Forums > General > Vendor Announcements
Old 09-18-2004, 12:51 PM   #1 (permalink)
Reputation: Edo Performance is more helpful than not
HKS Sequential Blow Off Valve Kit for Subaru WRX
US$300
Product Description
Application: Subaru Impreza WRX
This part is heavily back-ordered everywhere in the States, and we have stock WITHIN THIS WEEK! Don't hesitate, grap one while stock lasts!
Application: Universal
The HKS Super Sequential Blowoff Valve (SSQV) is a dual stage pull type relief valve. Unlike other blow off valves that are push type, the SSQV will not leak under high boost conditions nor under vacuum at idling mode.
Being of a pull type valve structure, the SSQV will not leak under any level of boost because boost pressure also keeps the valve closed against its seat. The SSQV is actuated by pressure alterations only, not by the rate of pressure or vacuum in the line, which ensures a quick valve response and complete closure during idling mode.
On typical blow-off valve designs, a large valve is utilized in order to accommodate high boost / high horsepower applications. However, these large valves tend to react slowly and require high activation pressure to open and therefore are not able to activate and prevent compressor surge at light-load conditions. For Universal SSQV applications, weld-on flanges are available in steel and aluminum for custom installation.
Call in 512-462-0125 or mail gwen@edoperformance.com for inquiry. We welcome reasonable negotiations !
Old 09-20-2004, 10:26 AM   #2 (permalink)
bump
Old 09-21-2004, 01:24 PM   #3 (permalink)
bump
