-   Vendor Announcements (http://www.wrxtuners.com/forums/f85/)
-   -   Header + Uppipe Deals from JSC Speed!! (http://www.wrxtuners.com/forums/f85/header-uppipe-deals-jsc-speed-4152/)
Zullard 02-03-2004 08:18 PM
[SIZE=3][B]717-397-4637 or [email]Jon@Jscspeed.com[/email][/B][/SIZE]
[URL=http://www.jscspeed.com]www.jscspeed.com[/URL]
<B>10 GT Spec Gen II (newest) Headers + Uppipes in stock.</B> Comes with all gaskets and everything to install. Your Price is [COLOR=red]$499 Shipped![/COLOR] while supplies last, give us a call to get this deal and mention WRX Tuners.
[IMG]http://www.jscspeed.com/part_pictures/gtspec_wrxheader.jpg[/IMG]
<I>This is a 4 into 1 GT-SPEC stainless steel header. No bending or frame modifications are necessary for fitment. Dyno proven 25 horsepower/35 lb-ft of torque gain. includes a detachable up pipe. Fully stainless steel backed with GT-SPEC's 2 year warranty. Includes all gaskets. </I>
<B>12 Borla Header / Perrin Uppipe combos in Stock. </B> Gaskets not included. Price is [COLOR=red]$599 Shipped![/COLOR] while supplies last, give us a call to get this deal and mention WRX Tuners.
[IMG]http://jscspeed.com/part_pictures/borla_header.jpg[/IMG]
<I>T-304 stainless steel ceramic coated header for your WRX from one of the most trusted names in the business for an unbelievable price, what more could you ask? 4 to 1 tubular header (Latest Version!!)
</I>
[IMG]http://www.jscspeed.com/part_pictures/perrin_uppolish.jpg[/IMG]
<I>Perrin designed their uppipe to lower your WRX's turbo spool time by 500 RPM's. This unit is constructed from T-321 stainless steel, is entirely tig welded, and has 1/2" thick flanges to prevent warping. Perrin has found through extensive testing that factory ECU does not use the EGT sensor in the uppipe for Air/Fuel adjustment, so their design eliminates it. The EGT sensor's readings are a fail-safe in case temperatures exceed 1800 degrees.
As boost levels increase, the sensor will read falsely -- putting the car into "limp home" mode, decreasing performance and reliability. Additionally the sensor is fragile and can be easily damaged during removal and installation, which could lead to the sensor breaking off and destroying the turbo. Therefore, this uppipe includes an EGT sensor bypass to eliminate all the problems associated with the factory sensor. Includes detailed, illustrated instructions (a must for this installation), all new studs, and a no check engine light guarantee. This is an extremely durable piece, constructed from stainless steel with 1/2" thick flanges and a polished finish. Works on all 2002-2004+ WRXs. </I>
Zullard 02-03-2004 11:23 PM
Also wanted to mention we have 5 WRX Perrin Front mounts in stock (bigger than the APS DR500) call for a deal if you mention WRX Tuners!!
[url]http://jscspeed.com/wrx/intercoolers/perrin_fmic.htm[/url]
[url]http://www.jscspeed.com/wrx/project.htm[/url]
