EDI Performance
License plates are a necessary evil on the front of our cars, but you can save your front bumper from looking boring or blocking flow to your FMIC with the GrimmSpeed License Plate Relocation Kit. Utilizing our unique Infinite-Adjust design allows for virtually any mounting position and angular adjustment so you can mount it where you want it! Our simple design mounts in the OEM tow hook location for maximum support while providing you with the largest range of adjustment available on the market. With laser cut and powder coated 5052 Aluminum, this bracket will hold your plate confidently in place while looking sharp and light. Each tow hook adapter is custom designed and CNC machined from 12L14 and then treated with black zinc for an indestructible and perfect fit.
Re-defining style, it's what you can expect from GrimmSpeed.
*Features*
* Most adjustability available on the market!
* Mounts in OEM tow hook location (No cutting or drilling required)
* Simple stainless steel allen key hardware
* Will not block flow to your FMIC and can be adjusted to not block fog lights (Adjustments available for maximum air flow)
* Indestructible Black Zinc coated 12L14 shaft (This will not bind and break off in your tow hook hole like cheap aluminum kits)
Retail $79.99 + Shipping
Your Price $70 Free Shipping
