Go Back   Subaru WRX Forum: WRX Forums > General > Vendor Announcements
Old 10-04-2004, 07:05 PM   #1 (permalink)
Reputation: Edo Performance is more helpful than not
DEFI, Power Enterprise for Impreza, GREDDY BOOST CONTROLLER & TIMER, APEXI TIMER ....
We carry variety of DEFI-D gauges. Boost, oil Pressure, Temp, Fuel pressure, EGT, A/F ratio and Tachometer.
Check out the PRICES and DESCRIPTIONS HERE
Call in 512-462-0125 or mail gwen@edoperformance.com or PM me for inquiry. mention wrxtuners.com when contacting us. We welcome reasonable negotiations and group buy !
HKS EVC 5
US$500
HKS EVC V
HKS's all-new EVC is the first boost controller to feature integrated CPU's in each component (Display Unit, Control Module, and Stepping Motor) for more precise control, quicker response and improved boost pressure stability. This race proven, CARB-exempt system is available in either KPA or PSI measurement and features an easy-to-read LCD panel that can be positioned separately from the control module for driver convenience.
Feature and Benefits:
Compact Design The new ¼ din control unit, ½ DIN display unit and stepping motor are all compact in design, making for easier installation and mounting inside the cockpit and in the engine compartment;
Digital & Analog Display The digital display shows real time / peak hold measurements while the adjustable range analog bar graph helps with intuitive perception of boost levels;
Wide Screen Multi-Display A reverse illumination white display allows for improve visibility in various lighting conditions. The display shows multiply measurement readings for on the spot data confirmation;
Intelligent Stepping Motor A CPU is imbedded into the stepping motor. This creates more direct and accurate control as the CPU virtually eliminates lag time between the stepping motor and control module, thereby increasing linear boost control and stability;
High Boost Capability A wide range of boost control is possible, from stock boost all the way up to 250 kPa (2.5 bar / 36.25 psi);
East Boost Set-Up 2 individual boost levels can be easily set by simply turning the volume knobs of the control module;
2 Mode Boost Setting Function Separate A and B boost level settings can be tuned according to the user's preference and can be switched via the control module or display unit;
Peak Hold Function A peak hold function monitors and displays highest boost level attained to aid in tuning and performance. The peak hold valve is simultaneously displayed with the real-time measurement for full data viewing;
Scramble Boost Function A scramble boost function is integrated in the display unit. When the SBC button is pressed, an increased boost level is triggered for a selectable amount of time between 0-40 seconds;
Warning Function When boost levels exceed the warning levels, the display will flash and a buzzer will sound while the boost level returns to its baseline setting to protect possible engine and turbo damage. The warning boost level is also displayed as part of the multi-display data;
Stock Boost Return Function When the EVC is turned off, the boost level setting will automatically return to stock (baseline boost);
WasteGate Selection Function Can be used with either internal (swing valve) or external (poppet style) wastegates;
Dimmer Function The display unit illumination can be adjusted for user preference;
Data Memory Function Data memory is stored in a CPU in each component. Therefore settings are retained if power is disconnected;
Data Lock Function A security code can be inputted to protect against accidental changes in settings.
product link HERE
Call 512-462-0125 or mail gwen@edoperformance.com or PM me for inquiry. Mention wrxtuners.com when contacting us. We welcome reasonable negotiations and group buy !
GReddy PRofec B-spec II (Boost Controller) in BLACK/SILVER
US$315
The GReddy PRofec B-spec is one of the simplest, easy to use electronic boost controllers on the market today. Available in either Black or Clear Blue cases, the B-spec uses a reliable twin-solenoid valve control motor. There are two presets labeled Lo. and Hi., as well as a Balance knob to alter the wastegate boost response. This unit also can be used with both integral/actuator or external/poppet style wastegates Good for twin and sequential turbo setups. Compatible with our Remote Switching System.
Product link HERE
GReddy Full Auto Turbo Timers (Black/Silver)
US$77
Greddy Full Auto Turbo Timer (2002 series) - The NEW Greddy Turbo Timer offers vast improvements over the previous unit. This unit features the standard preset countdown as well as full auto mode which automatically counts down a calculated time based on engine rpm. On top of the turbo timer mode, there are many other modes including battery mode which allows you to monitor in real-time the battery voltage and also features a battery voltage warning mode to alert you if voltage is too high.
Speed mode allows you to monitor real-time vehicle speed with peak and warning modes.
Lap mode allows you to record up to 30 laps and can show you the "best" lap of those times.
Attack mode allows you to record 0-200m, 0-400m, 200-400m, 0-100km/h, 0-200km/h & 50-100km/h times.
All time recording functions can be controlled using the Greddy Remote Switching System.
Turbo Timer Harnesses are available separately.
Product link HERE
Apexi Auto Timer
US$89
Main Features
Suitable for all turbo vehicles.
Delayed engine shut off
Displays Oxygen level, Air/fuel ration
Display Air/fuel optimal curve (when used with S-AFC or V-AFC)
Apexi Auto Timer
The Apex Auto Timer allows the vehicle to idle for a preset period of time after the ignition key has been removed. In turbocharged vehicles this prevents hot oil in the engine from coking up in the lines.
Hard driving can raise engine oil temperatures to dangerously high levels. Proper cooling down is essential for a healthy turbo and engine. In a normal aspirated cars, the Auto Timer can also be used to warm/cool the inside of the car without having to sit inside. The Auto Timer stands as a technological marvel. The pen shaped, compact size makes the Auto Timer one of the smallest turbo timers on the market. This allows a clean and stylish installation virtually anywhere inside the car. The unique multi-angle joystick button allows easy navigation through the many feature menu.
To prevent potential theft while running, the handbrake safety feature shuts off the vehicle when the handbrake is released without the ignition key.
Products link HERE
Call 512-462-0125 or mail gwen@edoperformance.com or PM me for inquiry. mention DSMTuners when contacting us. We welcome reasonable negotiations and group
Power Enterprise Turbocharger Kit (Impreza A/R20) with separate actuator
Power Enterprise Timing Belt for EJ20 (Impreza / STi)
Call in (512)462-0125 or mail gwen@edoperformance.com or pm me if interested. Make sure to
mention clubwrx.net !
