Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Bolt-on Tech (EJ255/EJ257 2.5L '04-07 STi and '06-07 WRX)
Old 08-13-2003, 12:18 AM   #1 (permalink)
Reputation: cadprowrx is an unknown
Question WRX EJ20 vs STi Motor
As far as hardware goes, what's the difference between my WRX motor and the STi motor. I know that they bumped the ccs to 2.5l, but did they increase bore or stroke or both? Also, what other things did they do? Different rods? Compression?
I know it has variable valve timing... so you don't have to include that!
Old 08-13-2003, 07:12 AM   #2 (permalink)
Cosmo's Avatar
Images: 15
Reputation: Cosmo is known to be trustworthy and helpful Cosmo is known to be trustworthy and helpful
Compression is slightly higher in the STi (I believe 8.5:1 as opposed to the WRX's 8:1). Bore and stroke are larger/longer. As far as internals, I believe the rods are the different because of the different crankshaft. And, naturally since it has larger bore, the pistons are different.
Old 08-13-2003, 11:21 AM   #3 (permalink)
jwtarbaj's Avatar
Images: 11
Reputation: jwtarbaj is more helpful than not
If I'm not mistaken I read that the block is different too. I'm not sure how. Anyway if you want a bigger motor for your Rex you could do a stroker kit and perhaps even an overbore. The stroker is good for 2.2L I believe and the overbore would add a little more. This is expensive work though.
Old 08-13-2003, 11:36 PM   #4 (permalink)
Thanks for the replys. Not interested in punching out my motor, just had a friend ask what the difference was between my WRX and the STi...
Old 08-15-2003, 04:15 PM   #5 (permalink)
Reputation: Zullard is more helpful than not
Aluminum engine block and forged pistons and rods.
[webpage] [posts] Reply With Quote
