will mixing octane work? - Subaru WRX Forum
post #1 of 6 Old 10-24-2008, 11:40 PM Thread Starter
06dubbrx ltd is an unknown
I was googling 93octane in socal, and it broght me to the caymans club forum. They were talking about filling your car with mostly 91 and then adding in a couple of gallons of 100octane, and you make 93 or 94 octane. Is this true? There are places here that sell 100. VP Racing gas station in Ontario has it for $8.99 a gal. How much should i put?
06dubbrx ltd is offline
post #2 of 6 Old 10-25-2008, 12:21 AM
You can do this, works fine. It's important though that you be consistent. If you get it tuned at a certain ratio, make sure you use at least that much EVERY time you add gas. NO exceptions.
If you want to Raise 91 Octane with 100 octane to... for a 9 Gallon Fillup:
91.5 Octane | 17 to 1 Ratio | 8.5 Gallons of 91 and 0.5 Gallons of 100
92.0 Octane | 8 to 1 Ratio | 8.0 Gallons of 91 and 1.0 Gallons of 100
92.5 Octane | 5 to 1 Ratio | 7.5 Gallons of 91 and 1.5 Gallons of 100
93.0 Octane | 3.5 to 1 Ratio | 7.0 Gallons of 91 and 2.0 Gallons of 100
93.5 Octane | 2.6 to 1 Ratio | 6.5 Gallons of 91 and 2.5 Gallons of 100
94.0 Octane | 2 to 1 Ratio | 6.0 Gallons of 91 and 3.0 Gallons of 100
94.5 Octane | 1.6 to 1 Ratio | 5.5 Gallons of 91 and 3.5 Gallons of 100
95.0 Octane | 1.25 to 1 Ratio | 5.0 Gallons of 91 and 4.0 Gallons of 100
95.5 Octane | 1 to 1 Ratio | 4.5 Gallons of 91 and 4.5 Gallons of 100
at 93, 22.2% of your gas needs to be 100 Octane. At 94, 33.3% of your gas needs to be 100 Octane. Figure $9 for 100 octane and $3 for 91 octane, you are effectively paying $4.33 for 93 octane and $5.00 for 94 octane.
If you really want to do this, I suggest driving to the 100 octane place and filling up 2 or 3 (depending on which octane you want) gas tanks and then driving to a regular gas station. Make sure your tank is fairly run down so you can fit it and then dump in the good stuff followed by 7 or 6 gallons (depending on which octane you want) of the regular stuff.
post #3 of 6 Old 10-25-2008, 01:24 AM
Do you really think you'de keep up on that? That would last maybe 2 times for me...
post #4 of 6 Old 10-25-2008, 06:38 AM
Merk247's Avatar
Merk247 is an unknown
Send a message via AIM to Merk247
seems like a lot of work..but for the added performance and not having 93 avail. i guess it would be worth it
Mr.Transmort
If you have everything under control you're going too slow..
Merk247 is offline
post #5 of 6 Old 10-25-2008, 09:59 AM
silverSTi's Avatar
silverSTi is an unknown
that seems like a lot of work, lucky for me i can just fill with 94 right from the pump!
Byron
silverSTi
silverSTi is offline
post #6 of 6 Old 10-27-2008, 10:07 PM
I would so get bored of something that trivial. But to each their own.
