White smoke - Subaru WRX Forum
post #1 of 24 Old 05-29-2013, 08:29 PM Thread Starter
06_hawk_eye's Avatar
06_hawk_eye is an unknown
White smoke
So today I drove to sonic shut off the car and waited about ten minutes started it back up and bam white smoke drove about 100 ft and it stopped. Drive down the road and went into boost no smoke. Drove around for 10 mins in and out of boost and no smoke. Only smoked on the start up. Any ideas going to pressure test tommorow see if it holds pressure
Sent from AutoGuide.com App
06_hawk_eye is offline
post #2 of 24 Old 05-29-2013, 08:38 PM
thekamikaze kid's Avatar
I have been having this on and off fer a year! I still dont know what it is. where is it coming from? mines been coming from under the heatshield area, and is sometime excessive out the exhaust.
thekamikaze kid is offline
post #3 of 24 Old 05-29-2013, 08:59 PM
hjust doin a little searchin' and found that the 02-03 models seam to have this problem alot. anyone have any thoughts?
post #4 of 24 Old 05-29-2013, 09:00 PM Thread Starter
Yeah mine was crazy out the exhaust popped the hood and nothing. Check your axle boot when that rips it'll sling grease onto the downpipe and cause smoke. That might be your problem. But idk what mine is ima pressure test it tommorow and see what's going on.
post #5 of 24 Old 05-29-2013, 10:24 PM
Condensation, I've researched this before and it's pretty common.
7/10 find that to be the issue
post #6 of 24 Old 05-29-2013, 10:49 PM Thread Starter
Lets hope your right randy I'm really not looking forward to putting head gaskets in
post #7 of 24 Old 05-30-2013, 07:33 AM
Check your oil first, that would be your dead giveaway. Cloudy white foam
post #8 of 24 Old 05-30-2013, 08:07 AM Thread Starter
Pressure tested it this morning before work held fine started car and pressure stayed the same. Checked oil it's just dark gonna change it next week. The weird thing is that it didn't smoke this morning. Went in and out of boost fine no smoke behind me. No signs of any leaks underneath.
post #9 of 24 Old 05-30-2013, 07:24 PM Thread Starter
Started car after work just fine drove it into the shop all good. Go to clean off the excess coolant that dripped everywhere when pressure testing. And bam white smoke again this time noticed it had a little blue ish tint. Now thinking possible turbo seal. Any ideas
post #10 of 24 Old 05-30-2013, 07:42 PM
You can tell if it's the turbo by letting it idle a long time on initial startup.... if it smokes after 10 or so mins (at idle) it's prob the turbo.
post #11 of 24 Old 05-30-2013, 08:00 PM Thread Starter
Taking it into Subaru tommorow. I'm hoping its just the turbo and nothing more like possible rings
post #12 of 24 Old 05-30-2013, 09:22 PM
I took mine to subaru when that happened, said on the receipt "could not not reproduce smoke", so make sure you push the problem!
post #13 of 24 Old 05-30-2013, 09:27 PM Thread Starter
Yeah mine happens if you let it warm up then rev it up a
post #14 of 24 Old 05-30-2013, 09:29 PM Thread Starter
Rev It up ad you can see little blueish/ white smoke of you stand behind it while someone else is on the gas you can see it. Gonna have compression test done as well
post #15 of 24 Old 05-31-2013, 07:20 PM Thread Starter
Let it run in the shop tonight for about 5 mins then reved it to about 3500 and it smokes make me think its the turbo.
