I got some about 3 months ago but now the brightness has faded so much that they hardly light up the road. Price isn't a concern, I just want to know what is the best ones to get so the bulbs don't fade in 2 or 3 months. The ones I got were from Ebay so they had no warranty. I found this HID site which covers the bulbs for a year, but what color should I get? I want one that's really bright and still looks cool. This site like any other sites recommends 6000k? Is it true?
I don't know if any of you have experienced this, but one of my HID bulbs turned really purple and then burned out after ~2.5 years and ~55k miles, so I had to replace both bulbs since the one that was still good was a noticeably different color than the new one.
(Sharp HID 35w 5000k, daytime running lights NOT disabled)
Also, the holes that I had to cut through the plastic caps behind the lights to feed the HID bulb wires through were allowing a bit of moisture into the headlight housings through the rubber grommets that were supposed to seal them completely, so I had to remove both headlight assemblies from the car and bake them in an oven to dry them out really well and then use some silicone to seal up the space between the rubber gromets and the plastic caps... at that point I probably should have just done a retrofit.
I agree, a retrofit is certainly the best way to go, but in my opinion, the stock 06/07 WRX projector headlight housings aren't nearly as bad as some other cars that I've seen with extremely glarey aftermarket HID kits (older Civics and Scion TCs with reflector housings immediately come to mind).
go to xenonhidconversionkit.com and get a 55w canbus ballast hid kit for 110$
this is the best hid kit u can get. i installed mine on my wrx 2010 and its still working like new. i have no flickering issue and no lamp out on the dash. installation is also really easy. 100% plug n play. they offer free shipping and lifetime warranty. my hid kit work perfecty. car cover car tint
:rocks:
GO to theretrofitsource.com. They have a good variety of quality kits and instructions and everything u need to retrofit. i got a morimoto setup from them after using the shitty ddm ones, very happy, honest pricing. amazing cust service too!!Thumbs Up
