-   -   What are the best HID kits? (http://www.wrxtuners.com/forums/f75/what-best-hid-kits-30511/)
doglover2050 04-01-2011 11:20 AM
I got some about 3 months ago but now the brightness has faded so much that they hardly light up the road. Price isn't a concern, I just want to know what is the best ones to get so the bulbs don't fade in 2 or 3 months. The ones I got were from Ebay so they had no warranty. I found [URL="http://www.xenonheadlights.net/"]this HID site[/URL] which covers the bulbs for a year, but what color should I get? I want one that's really bright and still looks cool. This site like any other sites recommends 6000k? Is it true?
Thanks in advance!
VD5505 04-01-2011 02:40 PM
Go to Sharp HID. I have 55 watt ballasts with the Heavy Duty wiring harness and 6000k lights. they are so nice and bright white.
basco 04-01-2011 03:29 PM
what type of headlight housings do you have? If they're not retrofitted your doing all of your fellow drivers a great dis-service by putting HIDs in
turmic 04-01-2011 04:43 PM
And we started a retrofit thread down in the non-performance forum. :sneaky:
basco 04-01-2011 05:15 PM
^ I saw that! I still think the best retrofit is either get the JDM factory HID units or the same model STi
brfatal 04-02-2011 01:38 AM
You can't use an HID kit if you don't have headlight that came with HIDs stock. Even then it is, it's still the wrong way to go about it.
[quote=VD5505;258879]Go to Sharp HID. I have 55 watt ballasts with the Heavy Duty wiring harness and 6000k lights. they are so nice and bright white.[/quote]
You're an inconsiderate buffoon. Keep you ill-wisdom to yourself.
man show 04-02-2011 11:00 AM
I don't know if any of you have experienced this, but one of my HID bulbs turned really purple and then burned out after ~2.5 years and ~55k miles, so I had to replace both bulbs since the one that was still good was a noticeably different color than the new one.
(Sharp HID 35w 5000k, daytime running lights NOT disabled)
Also, the holes that I had to cut through the plastic caps behind the lights to feed the HID bulb wires through were allowing a bit of moisture into the headlight housings through the rubber grommets that were supposed to seal them completely, so I had to remove both headlight assemblies from the car and bake them in an oven to dry them out really well and then use some silicone to seal up the space between the rubber gromets and the plastic caps... at that point I probably should have just done a retrofit.
I agree, a retrofit is certainly the best way to go, but in my opinion, the stock 06/07 WRX projector headlight housings aren't nearly as bad as some other cars that I've seen with extremely glarey aftermarket HID kits (older Civics and Scion TCs with reflector housings immediately come to mind).
VD5505 04-02-2011 11:55 AM
[quote=brfatal;258914]You can't use an HID kit if you don't have headlight that came with HIDs stock. Even then it is, it's still the wrong way to go about it.
You're an inconsiderate buffoon. Keep you ill-wisdom to yourself.[/quote]
I hope you kidding me right?? I have installed THIS same kit in 4 other friends cars. All them came without HID's in them. This kit comes with the ballasts, wiring/ relay and bulbs. So please tell me WHY a person CAN'T use an HID kit if you dont have headlights that came with HID's stock?????
basco 04-02-2011 12:14 PM
because you end up with this
<img src="http://www.intellexual.net/hids/3.jpg" /img>
which blinds the on coming driver
brfatal 04-04-2011 10:23 AM
[quote=VD5505;258929]I hope you kidding me right?? I have installed THIS same kit in 4 other friends cars. All them came without HID's in them. This kit comes with the ballasts, wiring/ relay and bulbs. So please tell me WHY a person CAN'T use an HID kit if you dont have headlights that came with HID's stock?????[/quote]
So because something fits it means it's suitable for use?
And you're not just a fool for installing this crap on 1 car, but on 5? :pity: Hope you don't happen to run across me on the road, because I've had no problem returning favor with 100w driving lights.
This is what you consider "so nice":
[IMG]http://i52.tinypic.com/2qi4v1j.jpg[/IMG]
VD5505 04-04-2011 11:57 AM
Well think what you want!! Non of them look like that at all!!
pzr2874 04-04-2011 02:17 PM
What car does the OP have ?
Brian, I'd like to see some links you have used... Might help the OP as well.
drizzy 07-19-2011 06:56 PM
Hey man Ive bought these acouple of times and they are really good. Never faded or anything like that. If you want you can give them a try.
[url=http://www.carhidkits.com]HID Kits - Xenon Kit - Car Lights[/url]
turmic 07-19-2011 09:38 PM
With a retrofit or STI HID headlights.
pocketrocket41 08-07-2011 01:10 PM
sorry new here but how do u retrofit?
