Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Bolt-on Tech (EJ255/EJ257 2.5L '04-07 STi and '06-07 WRX)
Old 10-28-2009, 08:08 PM   #1 (permalink)
Car: 04 WRX
Reputation: brouib is an unknown
wastegate actuator question
I am about to drop in my ej255 and the wastegate actuator on my 20g keeps getting stuck so I need to replace. I am running low on cash and the ej255 i just bought comes with the stock turbo.
my question is can the stock td04 wastegate actuator work on my 20g until i can buy one from Forge?
Also does anyone know the stock psi rating for the stock td04 turbo? Thanks.
Old 10-28-2009, 09:07 PM   #2 (permalink)
boo-key bear's Avatar
Club Region: Southeast
Images: 16
Reputation: boo-key bear is an unknown
11.6 p.s.i. is the stock boost rating on my 06 wrx if that helps any. As far as the wastegate actuator I dont know.
TURBO+AWD=REPLACEMENT 4 DISPLACEMENT
Old 10-29-2009, 03:45 AM   #3 (permalink)
midniteblack's Avatar
Club Region: Southwest
Reputation: midniteblack is more helpful than not
Send a message via AIM to midniteblack
Originally Posted by boo-key bear View Post
11.6 p.s.i. is the stock boost rating .
I believe a stock wrx should be somewhere around 13.5psi.
Old 10-30-2009, 10:08 AM   #4 (permalink)
Car: 04 WRX
ok so thats cool for now.
so no one knows if that wastegate actuator would work on my td05 20g?
Old 10-30-2009, 08:51 PM   #5 (permalink)
Images: 16
2006-2007 (stock)
WRX: 11.6 P.S.I. WRX STI: 14.5
I am not sure if it is the same for other years.
Old 10-30-2009, 09:00 PM   #6 (permalink)
These are the factory pre-tensioned wastegate settings. What 20G are you running. According to the 20Gs that Blouch uses they are both pre-tensioned to 9PSI. So if the table I found is correct, one from an 04-07 STI, or maybe an 02-03 WRX might work. But not sure, and not sure if the table is helpful or not either.
2007 STi WGDC Tables
Stock restrictor pill size = ~.0335”
Factory wastegate pre-tensioned to ~9psi
2004-2006 STi WGDC Tables
Stock restrictor pill size = ~.043”
Factory wastegate pre-tensioned to ~10psi
2007 WRX WGDC Tables
Stock restrictor pill size = ~.028”
Factory wastegate pre-tensioned to ~6psi
2004-2005 WRX WGDC Tables
Stock restrictor pill size = ~.047”
2002-2003 WRX WGDC Tables
Old 10-31-2009, 05:30 AM   #7 (permalink)
2006-2007 (stock)
It's different for different years. the op's car (04') runs 13.5 psi as well as the rest of the usdm 2.0 wrx's. The 06-07 is 11.6, 08' is 11.9 and 09+ is 13.3. So i've heard from my sources
Old 11-02-2009, 10:00 PM   #8 (permalink)
Pretty sure it will not work due to the bolt holes are different.
Aarg matey!
ECU Pirated by RomRaider
