TurboXS TBE, turbo creep...???? - Page 2 - Subaru WRX Forum
post #16 of 20 Old 09-20-2011, 10:30 AM
I would say only run the intakes that Cobb is asking you to run. COBB Tuning . Subaru STI AccessPORT . Map Listing Which says to run a stock intake or Cobb SF Intake. Realistically if you want to run anything other than that...you should get it pro-tuned.
If you want to run the TBE without a tune...then you will have to stay out of the boost and no WOT runs. Otherwise you will have boost spikes, fuel cuts, and possible that your ecu will go into limp mode.
post #17 of 20 Old 09-20-2011, 12:45 PM Thread Starter
05STISuby's Avatar
05STISuby is an unknown
Looks like I'll play it safe and get the cobb tune before I get anything else just so I have it there when im ready to use it. thanks for all the input!
05 Subaru STI
2.5L, Bone Stock for now.
05STISuby is offline
post #18 of 20 Old 09-20-2011, 03:37 PM
black beast2's Avatar
black beast2 is an unknown
I'm pretty sure Cobb has a map for the AEM intake, if not from cobb maybe you can get it from AEM. You can run the cathack part of the exhaust intill you get the AP then throw on the DP, you won't see a power increase untill you flash stage 2 but atleast you'll have the sound in the mean time.
I don't have to be mad to punch someone in the face!
black beast2 is offline
post #19 of 20 Old 09-20-2011, 04:01 PM
Not for the 02-07s...look at the link.
post #20 of 20 Old 09-20-2011, 07:48 PM Thread Starter
05STISuby's Avatar
I thought the TBE from TXS wouldnt connect to the stock DP in the event that you did just use the catback section? if im wrong that would be awesome cause ill buy the exhuast first then lol
And yeah I dont think COBB has the map for AEM but ill check AEM and if not ill have to do a protune i suppose
05 Subaru STI
