turbo intake pipe - Subaru WRX Forum
post #1 of 19 Old 09-28-2007, 09:02 PM Thread Starter
rss3781 is an unknown
turbo intake pipe
i got a new turbo intake pipe silicon blue now all i get is 5 psi of boost no leaks. what do i do with the sensor right before my turbo? unplug and remove. any help would be great
rss3781 is offline
post #2 of 19 Old 09-28-2007, 09:40 PM
Jave's Avatar
Jave is more helpful than not
huh? should be a simple swap, is there anything not connected that was before or what? What senor are you talking about?
▼SbiΣ Mi▼
Jave is offline
post #3 of 19 Old 09-28-2007, 11:46 PM Thread Starter
sensor
the sensor on the inlet pipe 2006 wrx right befor the turbo on the top of inlet pipe
rss3781 is offline
post #4 of 19 Old 09-28-2007, 11:58 PM
Imprt4life's Avatar
Imprt4life is an unknown
Send a message via AIM to Imprt4life
Are you asking why you only get 5 lbs of boost or what to do with the sensor?............Or Both?
Imprt4life is offline
post #5 of 19 Old 09-29-2007, 01:18 AM
Im sure an explanation of both woul be great. Im kind of curious to why this happened also.
post #6 of 19 Old 09-29-2007, 07:32 AM Thread Starter
the sensor on the inlet pipe 2006 wrx right befor the turbo on the top of inlet pipe what is it? That is all i am asking
rss3781 is offline
post #7 of 19 Old 09-29-2007, 11:23 AM
Jave's Avatar
I think I know what you are talking about, but you need to plug it in. I bought a Ebay inlet pipe and had to cut a part off of the stock inlet because the fitting on the new one was no the right size. That might be of some help.
▼SbiΣ Mi▼
Jave is offline
post #8 of 19 Old 09-29-2007, 12:23 PM
If you can take a picture.What inlet pipe(Perrin,Samco...) and did it come with instructions?Did you reconnect the vaccum line that is right after the MAF pipe?It goes to the BCS.I think the "sensor" your talking about might be the evap solenoid that on older WRX's was mounted on the front of intake manifold just right of the inlet pipe.Some of the intlets require you to T off a couple of the vac lines.
dumdum is offline
post #9 of 19 Old 09-29-2007, 02:01 PM Thread Starter
instructions
did not get any instructions with it its a jdm part i think all vac lines are on and i cant find any leak but i am gettng a code p1491
rss3781 is offline
post #10 of 19 Old 09-29-2007, 02:23 PM
JDM part?You got it used or new?If you don't have the sensor hooked up then your going to get a CEL.
dumdum is offline
post #11 of 19 Old 09-30-2007, 10:22 AM Thread Starter
restrictor pill
ok i have a dyno tune reflash done car was great installed turboinlet pipe no boost over 8psi.
I justed looked at the turbo restrictor pill it was gone replaced with a pice of vac line. Did the tuner remove this for a reason? my tune boost was 18 psi. Do i need the restrictor pill or did the tecs remove or lose it during inlet pipe install?
rss3781 is offline
post #12 of 19 Old 09-30-2007, 11:36 AM
Do you have a 3 port boost solenoid?If you have the stock solenoid then you need the pill.
dumdum is offline
post #13 of 19 Old 09-30-2007, 03:42 PM Thread Starter
i am stock boost siln
stock boost control but i have the gm wating to install
rss3781 is offline
post #14 of 19 Old 09-30-2007, 04:25 PM
Jave's Avatar
then you need the pill that is most likly the issue.
▼SbiΣ Mi▼
Jave is offline
post #15 of 19 Old 10-01-2007, 04:37 PM Thread Starter
got the pill in
ok it was the pill one of the tecs there riped the hose and replaced it with just a some old hose and never told anyone. We found the old one in the tool box he was useing. Well back to 17 psi and 282hp . next mod is more tuning and the gm boost noid + a new sube clutch this one is shot out and will not hold WOT after 3 gear. anyone think i should take a new tmic from my shop or wait till i get a bigger turbo. current mods spt intake muffler and a downpipe + dyno reflash made 282-290hp. Any other mods i should do???? All ideas welcome Thankyou for all the help
rss3781 is offline
