This is total BS!!!!! - Subaru WRX Forum
post #1 of 21 Old 10-31-2007, 10:33 AM Thread Starter
Jonpark is an unknown
Send a message via MSN to Jonpark
hi everyone...
I got Perrin EL header last week and got it installed but hasn't finish yet...
because of an old(2007) oil cooler adapter has an rediculous angle to it so i needed a oil cooler adapter from 2002~2005 wrx... BUT!!!! it's not in this country!!! my local subaru dealers and parts stores said that i can't get it because it's not available in USA right now....but my car is on the lift and my stock header is off the car and giving me a BIG PAIN!!!!!!I'm so pissed off...i tried more than dozens of junkyards to find this part but...it seems like impossible. what should i do now....
291.11whp/321.13wtq 18psi
Jonpark is offline
post #2 of 21 Old 10-31-2007, 10:46 AM
Try emailing japanparts.com.
post #3 of 21 Old 10-31-2007, 12:27 PM
BAMBO's Avatar
BAMBO is an unknown
This guy always comes through for me !
http://www.jdmplace.com/
BAMBO is offline
post #4 of 21 Old 10-31-2007, 12:35 PM
IH8PVMNT's Avatar
IH8PVMNT is an unknown
HOnestly you dont even need a header... its a waste of money time and power
all you need is a turbo back with and ecu upgrade or some turbo porting
or a cat back for 06 and up... due to boost creep
trust me puitting in that header is just a waste of power its too much free flow
and knowing from experince on my buddies 05 wrx installed an turbo back and ecu-tek
ecu upgrade and dynoed 60whp then installed an header a few months later and redyno teested droped to 47whp.... unless there was any other problems with his car which there wasnt, and the ecu programm remained the same... i would suggest putting the stock header back in....
IH8PVMNT is offline
post #5 of 21 Old 10-31-2007, 01:02 PM
BAMBO's Avatar
BAMBO is an unknown
Sorry dude but thats total BS! Unless he got some piece of siht header or an aweful tune, it should have given approx 25whp & 30ft/lbs before a tune ! ! Headers are one of the best mods you can do to your car!
Check out Perrin's site ... they show numbers from their clients not their R&D
http://www.perrinperformance.com/pro...ory=6&model=18
BAMBO is offline
post #6 of 21 Old 10-31-2007, 05:35 PM
RedefinedWRX's Avatar
RedefinedWRX is an unknown
The DC Sports header fits FTW!!
07 WRX TR
- Alex
RedefinedWRX is offline
post #7 of 21 Old 11-01-2007, 06:15 AM
IH8PVMNT's Avatar
Unless its was tuned like shit but those are actual numbers.... i wouldnt bs
IH8PVMNT is offline
post #8 of 21 Old 11-01-2007, 09:33 AM Thread Starter
the main reason that i'm trying to put the header on is b/c of that heat in the #3 cylinder problem. stock header has weird bends to it so i wanna solve the heat problem that stock header has. my next mod will be perrin fuel rails.
Jonpark is offline
post #9 of 21 Old 11-01-2007, 12:01 PM
why fuel rails? u dont really need fuel rails unless u have a race only setup. injectors and fuel pump should be the only fuel system upgrade u need.
post #10 of 21 Old 11-01-2007, 12:36 PM Thread Starter
because i've searched org for long time and i found out that alot of people r having check engine(misfire) problem. and the solution to it was upgrade it to perrin fuel rail.
Jonpark is offline
post #11 of 21 Old 11-01-2007, 12:51 PM
an easier and cheaper solution is to replace ## spark plugs first. these cars run a little rich from factory and i think should replace spark plugs before the recommended mileage. especially with those 07's.
post #12 of 21 Old 11-01-2007, 01:11 PM
Jave's Avatar
Jave is more helpful than not
The reason the #3 has issue is the crappy design of the stock fuel rails. #3 runs lean because of this desgn hench the higher temps. After market fuels rails fix this but you can also modify the stockers to be parallel.
http://www.scoobymods.com/forums/sho...=fuel+rail+mod
▼SbiΣ Mi▼
Jave is offline
post #13 of 21 Old 11-01-2007, 01:14 PM
Jave's Avatar
Headers are more designed for higher revs. You lose some low end for a gain in top end but the gain comes just before your power curve is reaching its peak. Now the JDM spec engines see better gains but to the 8k redline.
▼SbiΣ Mi▼
Jave is offline
post #14 of 21 Old 11-01-2007, 01:20 PM
deandisease is an unknown
heres what you do
hi everyone...
You hire someone like myself thats a cnc programmer (metal worker) to make you a custom part its very easy and can be done in minutes. So pretty much call a machine shop
deandisease is offline
post #15 of 21 Old 11-01-2007, 03:33 PM
Okeyd57's Avatar
Okeyd57 is an unknown
I get mis-fires on #1 and #3 at times, but my tuner attributed it to my PE850 injectors rather than the fuel rails. You have my attention ! I think I'll mention that before I go up for my next tune ! Thanks.
Okey's Black Mamba-06 STi-OBP- Cobb stage 2
Okeyd57 is offline
