Tbe - Subaru WRX Forum
post #1 of 15 Old 08-28-2007, 10:19 PM Thread Starter
rubenc66's Avatar
rubenc66 is an unknown
Tbe
So i'm about to purchase an ebay TBE but a muffler place won't install it for me because the cat. converters won't be in n e more.........so i was just wondering if anyone has done this themselves and how easy/difficult it was?
rubenc66 is offline
post #2 of 15 Old 08-28-2007, 11:15 PM
WRXforME's Avatar
WRXforME is an unknown
Its one of the easiest things you can do. You take a few bolts off that connect the stock exhaust to the turbo, and then pretty much remove the exhaust from the hangers. Putting on the new one is easier than the removal of the old one. You will probably want to soak all of the bolts with PB Blaster or Liquid Wrench and let it sit for 15 min to loosen them up.
WRXforME is offline
post #3 of 15 Old 08-28-2007, 11:15 PM
Very easy. You can do it.
http://www.turboxs.com/faq/turboback.htm
Change your up pipe while you are at it. It makes sense to do it at the same time since the DP will already be out of the way. Otherwise you will have to take the DP back off to swap the UP.
Kjott21 is offline
post #4 of 15 Old 08-28-2007, 11:28 PM
WRXforME's Avatar
Eh, I wouldnt recommend you do an uppipe alone though. Its an extreme PITA. At least, the first time you do it it is.
WRXforME is offline
post #5 of 15 Old 08-28-2007, 11:29 PM
Wuss
Kjott21 is offline
post #6 of 15 Old 08-29-2007, 12:02 AM
thats only cause you did yours with ian.
Robby
02 rex is gone.
I defected to an evo :)
Evo is gone :(
Now I got nothing.
WRXKidid775 is offline
post #7 of 15 Old 08-29-2007, 12:09 AM Thread Starter
rubenc66's Avatar
hey thanks guys well looks like i'm gonna turn wrenches again just like in the army haha
rubenc66 is offline
post #8 of 15 Old 08-29-2007, 02:05 AM
its cakesauce man.
Robby
02 rex is gone.
Evo is gone :(
Now I got nothing.
post #9 of 15 Old 08-29-2007, 04:29 AM
dremers is an unknown
Originally Posted by WRXKidid775 View Post
its cakesauce man.
the first time its done its not easy.
dremers is offline
post #10 of 15 Old 08-29-2007, 04:41 AM
super easy.
dremers is offline
post #11 of 15 Old 08-29-2007, 06:40 AM
surfwalden's Avatar
surfwalden is an unknown
Send a message via AIM to surfwalden
the only pain in the butt is getting past all of the heat shields. I had to take mine out in 3 parts. But putting it back in was real easy. Like they said in the post above soak it first so you don't break a bolt. And make sure you use the new flanges, don't put the stock ones back on or you'll get an exaust leak
surfwalden is offline
post #12 of 15 Old 08-29-2007, 08:59 AM
WRXforME's Avatar
Was is absolutely necessary to post this in both 2.0 and 2.5 forums?
WRXforME is offline
post #13 of 15 Old 08-29-2007, 10:39 AM
WRXforME's Avatar
Yeah, the first time is the hardest, and you usually on need to do it once so you hate it
Ian, WRXKidid is talkin smack
WRXforME is offline
post #14 of 15 Old 08-29-2007, 06:19 PM
I did mine alone when I was a TOTAL NOOB with no assistance and it worked out fine.. Just take your time and get a service manual (there are free online ones) for tq specs..
Edit: also put some liquid gasket material on both sides of the new gaskets to make sure you don't get a leak.. Leaks SUCK...
post #15 of 15 Old 08-29-2007, 11:13 PM Thread Starter
rubenc66's Avatar
alright cool thanks for the help....and WRXforme i realized i posted this in the wrong forum so just tried to fix it before anyone got all pissed at me.
rubenc66 is offline
