Taking out AC / components - Subaru WRX Forum
post #1 of 9 Old 04-01-2008, 10:38 AM Thread Starter
Ok, so what increases / decreases does everyone have on this ? I know I will drop 50-75 lbs and all that (maybe more) I want to keep the bare minumum for defrost and straight air from outside.... Maybe just keep the compressor ? But what increases / gains would I see by getting rid of it ? I know I will need a new belt, timing, pulleys ? Suprised I was unable to find anything on it. Just a thought as I will be doing in on a weekend when the wife is not around
post #2 of 9 Old 05-20-2008, 07:15 AM
our cars timing dose not around the ac. When the compressor is not engaged im sure it robs a little power....but engaged with the ac on i have heard up to 15-20hp lost not to mention mpg. Our cars weight around 3000lbs with 224 hp that gives us a power to weight of 13.39. so every 13 pounds you remove from your car frees up a horse making it that much easier for your engine to pull it around. id say the compressor lines condensor and some of the wiring could put you in at 75+ lbs. removing that much weight you would feel the difference of about 6hp. but i think you could feel more becuase you are taking drag off of the crank by removing the compressor and putting in a shorter belt so if a full pulley kit gives you 12. we can guess removing compressor and shorter belt could give you 6hp. removing the ac completely could net you up to 12hp.....in theory.....
awdturb is offline
post #3 of 9 Old 05-20-2008, 08:53 PM
kh15's Avatar
the only reason i use mine is to keep everything all lubed up. every few months i turn on the a/c while my cars idling in the driveway.
windows down ftw!
kh15 is offline
post #4 of 9 Old 05-21-2008, 01:57 PM
I agree with you for the most part kh15, but I was also stationed in Ft. Polk, LA for 3 yrs, the south, especially around San Antonio is a whole different kind of heat.
post #5 of 9 Old 05-21-2008, 02:22 PM
You have had your car for what? 12 months? Don't do this. Someday sooner than you think you will sell that car and it will be a HUGE pain in the ass for what was really a very pathetically small gain.
post #6 of 9 Old 05-21-2008, 02:26 PM
SuBeast's Avatar
I'm not entirely sure about on the Subaru, but i've always heard people wanting to disconnect the A/C for more power, when in reality, sometimes you gain like what, 3hp? My 86' Corolla has the A/C belt off, and i didn't notice anything at all...
FAST
RELIABLE
CHEAP
Pick 2
2006 STi
1990 Toyota Hilux - daily
SuBeast is offline
post #7 of 9 Old 05-21-2008, 06:36 PM
IH8PVMNT's Avatar
the defroster uses the a/c. no compressor=no defroster
IH8PVMNT is offline
post #8 of 9 Old 06-06-2008, 12:28 PM Thread Starter
I hardly ever use my AC/defroster for that fact. Very soon, the rex won't be my daily driver and will be under construction....... Dunno.. It is ball-arse-hot here.
Mosc,
I have gone through .......ummmm..... Since 2000 this is my 5th car. I am done. The wife gets the next one. So, a minimum of 10 yrs till I get another car.....
post #9 of 9 Old 06-06-2008, 12:51 PM
do not underestimate the power of the STi side...
