-   -   Stage 2 injector problems? (http://www.wrxtuners.com/forums/f75/stage-2-injector-problems-32041/)
joshbm1 02-13-2012 11:57 PM
So i'm about to go stage 2 and have been warned by two people that the stock 2006 injectors may not be able to handle the extra fuel load. Has anyone had any problems with these and what are some good options for upgrades?
Also i have having a protune done, should this be covered in that tune?
Thanks All!
brfatal 02-14-2012 01:05 AM
Whoever told you this, knuckle in the eye.
pzr2874 02-14-2012 10:08 AM
You will be fine, the 565's are fine. Now, for an aggressive tune you will be maxing them out.
Is it a basic stage 2 tune?
brfatal 02-14-2012 11:29 AM
The stock turbo is completely incapable of maxing those out without running E85.
pzr2874 02-14-2012 01:03 PM
^I disagree Justin.
My 07 was at 95% IDC's .... Reason I asked what exact mods are done.... Mine had pretty much everything done except a build.
brfatal 02-14-2012 02:06 PM
[quote=pzr2874;275705]^I disagree Justin.
My 07 was at 95% IDC's .... Reason I asked what exact mods are done.... Mine had pretty much everything done except a build.[/quote]
That doesn't sound right. What's your setup? The 2.0L barely maxes out the stock 440s and the 2.5L only uses slightly more fuel while the injectors' peak flow is 25% again that of the 440s.
pzr2874 02-14-2012 02:23 PM
It was an 07.
newtothegame 02-14-2012 07:57 PM
Im with Paul, on 92 OCT I was able to max out my injectors with just a DP and a rather agressive tune. I just wanted to see what I could pull, and then went back down to a more peace of mind tune at the time.
joshbm1 02-15-2012 01:13 AM
I am doing 4" turbo xs catless dp/race pipe, jna cat back exhaust, with the cobb accessport and protune, and i am going to ask for a safe tune.
pzr2874 02-15-2012 06:45 AM
You will be fine.
blk05WRX 02-15-2012 02:54 PM
You'll be fine.
But, as an FYI, the new Cobb maps for 02-05 do "max out" the injectors. I was at 100% IDC with the old Stage 2 map, and with the new map they are at 110%. The new map sees about .5lb more boost and it kicks in a little earlier too when I graph the two runs together.
turmic 02-15-2012 06:03 PM
Add a fuel pump and you'll be in good shape. ;)
