Secondary Air combination valve - Subaru WRX Forum
post #1 of 8 Old 04-07-2013, 06:28 PM Thread Starter
jcole4455 is an unknown
Question Secondary Air combination valve
Need some info; I have a 06 WRX TR. I am looking to replace the air valve the p/n of the old one is 14831AA171. I cannot find that part anywhere. There are other p/n's not sure if they will work. Has anyone replaced theirs? What p/n's?
Thanks
jcole4455 is offline
post #2 of 8 Old 04-07-2013, 06:48 PM
06_hawk_eye's Avatar
06_hawk_eye is an unknown
I replaced mine it was the dumbest thing ever, the secondary air pump system is just for emissions. The valves are between 250/300 a piece and there's 2 of them one under the intercooler and one by the turbo. Your best bet would be go to your tuner and get them deleted from your engine bay an the codes deleted I might have the codes laying around if your interested or you can look online. All you need to delete them is 2 block off plates and te codes deleted . Just my .02
Sent from AutoGuide.com App
06_hawk_eye is offline
post #3 of 8 Old 04-10-2013, 10:10 PM
Chris-pee's Avatar
Chris-pee is an unknown
If I remember correctly you can just delete the codes in Accesstuner race if the only issues you are having with them is a code being thrown. Friend of mine had the same problem with his Fozzy XT. I could be completely wrong as well. It's been a while.
Chris-pee is offline
post #4 of 8 Old 04-11-2013, 06:24 AM
Still need to install the blockoff plates and then delete the code in ATR.
Was about to do this a yr or so back on my XT and all it needed was the connections cleaned and replugged in.
post #5 of 8 Old 04-12-2013, 08:49 PM
boo-key's Avatar
I just deleted mine. Prety easy with the intercooler off. If you want to take every piece of it off its much easier with the intake manifold off. Thats what I did since I had it off anyway. To delete it you at the least need to put block off plates on and remove those tubes that bolt to the heads. I would send you my old parts but I cut them up to get the sensor out. all I have left is the pipes, hoses, and plastic turbo looking thing. Also, if you do the delete get the ks tech plates and gaskets. The Cosworth ones are stupid expensive for all they are.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #6 of 8 Old 09-23-2013, 06:11 PM
crazyhorse2112 is an unknown
06 hawk eye...can you PM me those codes if you still have them please?
crazyhorse2112 is offline
post #7 of 8 Old 09-23-2013, 06:25 PM
Damn it's been awhile let me see if I can find them.
post #8 of 8 Old 09-23-2013, 06:36 PM
That's ok. I haven't been able to find exactly which ones to delete online. Even if you could direct me to someone else who might know I would appreciate it.
