sbr gt-12 on stage 2 07 wrx - Subaru WRX Forum
post #1 of 5 Old 05-05-2008, 07:03 PM Thread Starter
Just wondering if this turbo will go good on my car and what elese would i need beside bigger tmic, fuel pump and a tune. I know i should save up for ppg gears or similar.
sfelix818 is offline
post #2 of 5 Old 05-06-2008, 06:27 AM
You will need injectors and a downpipe also if you dont have eithe of them.
post #3 of 5 Old 05-06-2008, 09:16 AM
b7g
b7g's Avatar
To give you an idea Slow Boy lists a 55lbs/min compressor wheel, whereas a standard 20g turbo comes with 44-46 lbs/min. So gt12 is huge! I mean, Garrett GT30R is 52 lbs/min:eek:
So, to answer your question, I do not think it is a good turbo for a lightly modded car. You will need much bigger injectors, fuel pump, fuel rails, front mount, transmission, clutch, etc.
Hope this helps...
drive = freedom
b7g is offline
post #4 of 5 Old 05-07-2008, 06:57 PM Thread Starter
Thanks for the reply. Im going towards the 16g but I saw the gt-12 on ebay for $600 buy it now so I thought i would ask.
post #5 of 5 Old 05-08-2008, 11:57 AM
it's far from a bolt on turbo. You should add in considerable cost in your mind for piping, putting on a wastegate, etc.
