Rod Bearings - Subaru WRX Forum
post #1 of 16 Old 03-22-2012, 07:36 PM Thread Starter
thrice00 is an unknown
Rod Bearings
Hi guys,
I own a 04 Blue STI for a year now. Got an uppipe, turbosx downpipe hi flow cat and a cobb stage 2 91 ooctane since 6 months. I hit 90k km. Now my rods bearings are done and i need to open the engine....
Is it something that happen often? Is it the stage 2? Is it my oil pump that sucks and an oil starvation did that ??
I'M gonna rebuild with Forged Pistons(any advive?)
thanks for your time,
thrice00 is offline
post #2 of 16 Old 03-22-2012, 09:06 PM
2 biggest causes are detonation and bad oil. It could be the pump, but it rarely ever is. You're gonna want to replace that while you're in there.
post #3 of 16 Old 03-22-2012, 11:12 PM
You're going to want to get rid of the whole oil system...unless you know for without a shadow of a doubt that every speck and flake of the bearings is out of your oil system. If the shavings of the bearings are left behind...it can and will harm the new engine and turbo.
post #4 of 16 Old 03-23-2012, 04:32 PM Thread Starter
what kind of forged pistons would you put there? Just stage 2 91, Don't want to go further.
Forged pistons worth it ? I just want to be sure i'm not paying all this money to rebuild it in 2 years.
thrice00 is offline
post #5 of 16 Old 03-23-2012, 04:33 PM Thread Starter
WHat do you mean by detonation? Cobb map too generic?
thrice00 is offline
post #6 of 16 Old 03-23-2012, 08:55 PM
Some will argue that the Cobb OTS maps can/will cause issues in the long run. How long idk. I have known people to run them for over 2yrs before they got a protune or anything like it.
post #7 of 16 Old 03-23-2012, 09:38 PM
If you're not ever thinking of reaching 350whp/350wtq or more. Then you can skip on forged pistons...as long as you have a good tune.
post #8 of 16 Old 03-23-2012, 10:18 PM
They are ok for daily use. For people that beat on their cars, it can cause problems in the long run.
post #9 of 16 Old 03-24-2012, 09:46 PM
I've seen people blow up a motor on OTS maps. Jave who never gets on the forums anymore...he had a engine failure that was related to his Stage 2 OTS. Granted it took a little over 2 years for it to happen...its the long haul that makes it suspect.
post #10 of 16 Old 03-24-2012, 10:38 PM
<-- I'm one of them. I had Cobb's Stage 2 OTS map on my 2007 WRX for 3 years, 10 months, and almost exactly 75,000 miles (from 2/2008 @ 11,200 mi. to 12/2011 @86,200 mi, to be more specific) before I got a protune. I keep good records
post #11 of 16 Old 03-25-2012, 09:45 AM Thread Starter
thanks for your answers guys.
thrice00 is offline
post #12 of 16 Old 04-03-2012, 08:38 PM Thread Starter
Standard Rebuild with manley forged pistons. ASking if size 99.5mm -8.5 OR 9.8 C/R?
What do i choose.
OEM Engine Gasket Set -
Manley H-Beam Rods -
Manley Pistons - + tax bore size 99.5mm - 8.5 or 9.8 C/R?
ACL High Performance Rod Bearings - 52mm - STD Size with Extra Oil Clearance - $45 + tax
Killer B Oil pickup while there
thrice00 is offline
post #13 of 16 Old 04-04-2012, 12:07 AM
9.8? Who would use that? Are you sure it wasn't 8.9?
post #14 of 16 Old 04-04-2012, 07:12 AM Thread Starter
thrice00 is offline
post #15 of 16 Old 04-04-2012, 07:16 AM Thread Starter
But from the way you say that 8.5 is the way to go?
thrice00 is offline
