Questionable Headers? - Subaru WRX Forum
post #1 of 12 Old 08-10-2006, 02:50 AM Thread Starter
blk06wrx's Avatar
blk06wrx is an unknown
I saw these headers on ebay, they look cheap, I mean they're only about a hundred bucks anyway would it be a waste of money or a cheap 5-10hp? I'm not sure how to hyper link so you'll just have to copy and paste. http://cgi.ebay.com/ebaymotors/02-03...QQcmdZViewItem
blk06wrx is offline
post #2 of 12 Old 08-10-2006, 02:55 AM Thread Starter
blk06wrx's Avatar
Well I guess that worked
blk06wrx is offline
post #3 of 12 Old 08-10-2006, 09:32 AM
9d2TSi's Avatar
The top end gain that you might see with those will be offset by the low end power that you lose. If you're not running a larger than stock turbo and have head work done to raise the rev limit, it's a waste in my opinion.
9d2TSi is offline
post #4 of 12 Old 08-11-2006, 12:31 AM
brokenarrow is an unknown
You will spool your turbo faster with the stock one's.
But If you get some real HP in the motor I would get the aftermarket ones.
But this is just my 2 cents.
brokenarrow is offline
post #5 of 12 Old 08-14-2006, 09:51 PM Thread Starter
blk06wrx's Avatar
So I guess just leave it alone for now.
blk06wrx is offline
post #6 of 12 Old 08-16-2006, 07:09 PM
joker97's Avatar
joker97 is an unknown
you could lose low end torque changing these things alone. but of course unleash more high end potential should you go that path but you need other mods otherwise 1st scenario applies
joker97 is offline
post #7 of 12 Old 08-17-2006, 01:03 AM Thread Starter
blk06wrx's Avatar
Wouldn't the headers help when used along with a TBE?
blk06wrx is offline
post #8 of 12 Old 08-17-2006, 11:53 AM
the stock turbo runs out of oomph on it's own on the top end. Headers sacrifice bottom end to open up top end but your stock turbo can't take advantage of that so it'll basically only reduce your low end, cost you money, and that's about it.
Plus, most if not all headers on the market for the WRX were designed for the 8000rpm redline JDM STi so they're a poor match for a stock USDM motor. Power gains in the 6-8k RPM range do you no good.
post #9 of 12 Old 08-17-2006, 01:07 PM
Chris Rx's Avatar
Chris Rx is an unknown
from what i understand, lilshoaf is running stock manifold. if not him, someone else was running about 500 hp and running stock manifold. the header is yes for topend, but if stock turbo, and puttin anything less then 400hp i wouldnt change it
Chris Rx is offline
post #10 of 12 Old 08-17-2006, 02:43 PM
kh15's Avatar
kh15 is an unknown
i'd be cautious of any headers that only cost 100 bucks.
.2
kh15 is offline
post #11 of 12 Old 08-18-2006, 05:48 PM
ScoobyWRX is an unknown
What if you had the OEM exhaust manifold ported and polished?
ScoobyWRX is offline
post #12 of 12 Old 08-20-2006, 02:31 PM
Ian
Ian's Avatar
Ian is more helpful than not
Send a message via AIM to Ian
That would be the best thing to do
Ian is offline
