when it comes time to install this i use all new vacume line correct? no more pill, or T's? 3 new lines....
bcs to intake
bcs to wastegate
bcs to compressor
dont worry i will be installing this while my car is sitting on the dyno waiting to tune for the new prodrive unit!
no t's or pills will be uses when you install it. I'm not familiar with the prodrive BCS, I have the IR one that is the same as the Perrin, and it illiminates the BCS to intake.
<img src=http://i46.photobucket.com/albums/f137/SpDRcrWrex/WRX/my%20wrx/tech%20pics/ProdriveBCS_3port_hookup.jpg>
prodrive is the same just its plug and play. just wanted to make sure that i no longer need any pills or anything
Nope you'll run two vac lines (get new ones) no pills. One to wastegate actuator nipple and one to the turbo compressor nipple, zip tie them both.
The third you can just vent to the atmosphere and just plug your line that runs to your turbo inlet hose with something, I used an eraser off a pencil, perfect fit.
cool thanks! i had heard that you can have that 3rd vent to the atmosphere but i never read any pros and cons of doing it.
the bsc shipped today so im hopping to get it on and tuned in the next 2 weeks. damn td04! lol
1.) click on "xpt maps discussion"
2.) click on "HOW TO: DIY GM BCS Install
3.) click on http://www.tarmacwolf.org/dokuwiki/doku ... t_solenoid <<<<<-----------dont click on that one i meant the one after step 2^^^^^
4.) scroll down till get to the prodrive install portion
thanks! i had planned on doing it once my car was up on the dyno. im going to put the bcs in place and then plug it in and run the lines once i get to my tuner. im pretty sure you have to imediatly tune once installed or you will just overboost
you can install it now and you wont over boost,your ecu is still controlling it. I would just have it done before you get there.
