Go Back   WRX Forums > WRX Tech Forums > Bolt-on Tech (EJ255/EJ257 2.5L '04-07 STi and '06-07 WRX)
» Sponsor Links
»Garage Storage and Cabinets
Old 02-06-2008, 01:10 PM   #1 (permalink)
Club Region: Gulf Coast
Reputation: pzr2874 is an unknown
Port N Polish TD04
Ok ppl, I have been looking on the forums for a few days looking for feedback on doing this.
Is this an ok thing to do and if it is I have a few questions :
1- Grimmspeed is where I want to send it to.<---- Anyone have feedback on Justin ?
2- Worth the $250.00 ?
3- How to install it after I get it back. <---- heard this is a little tricky.
OR....
1- Just save for an 18g or 20g.
2- If and when I get the PnP.... and buy an upgraded charger, charge a little more on the resale of the TD04 ?
Old 02-06-2008, 04:26 PM   #2 (permalink)
Scooby2006's Avatar
Reputation: Scooby2006 is an unknown
u running sti or wrx, if wrx run the 18 if sti run the 20
Old 02-06-2008, 04:54 PM   #3 (permalink)
Reputation: psinuse is more helpful than not
Send a message via Yahoo to psinuse
I have never had any personal dealings with Justin, but have heard my good things about him. As for your choice in turbochargers, you have to consider with the PNP turbo you can get away with running factory injectors and a tune, with a bigger turbo you need all the supporting mods and a tune to go with it, plus it really depends on what you are wanting out of the car in the first place.
________________
I never really think.
Keith
Old 02-06-2008, 05:58 PM   #4 (permalink)
Reputation: Kjott21 is known to be trustworthy and helpful Kjott21 is known to be trustworthy and helpful
Justin is an awesome vendor. If you are thinking of upgrading to a larger turbo then I wouldn't waste the money on getting all that work done to the stocker. Just wait and get the ported option on the bigger turbo when you go bigger. It won't add that much value to the stocker to have it P&P.
Old 02-06-2008, 06:41 PM   #5 (permalink)
10-20HP for PnP so I heard. Even at the crank it 7-16, not to mention the slight spool time increase. Not bad for 250.00. I have the WRX. Plus the coating all for 250.00. Might even help w/under the hood temps, regardless if it's only 10-20 degrees. I live in an inferno. Not much price difference between the 18 and 20. 16g and TD04/with a PnP, arent too far off from each other save spool time and all that. <-----Correct me if i'm wrong
Old 02-06-2008, 06:48 PM   #6 (permalink)
There is a big flow difference between the TD04 and a 16g. If I were you I would look at a TD06 20G for your 2.5L motor. It would make an awesome daily driver turbo.
Old 02-06-2008, 10:00 PM   #7 (permalink)
What is your goal for the car? A number that you are aiming for would help some also. If you want a quick spool and power the TD05 20G should be a nice go for you with having a 2.5. Thats probably eventually what I will go with at least.
"Stage 2, not so cool anymore, starting to get bored now."
Old 02-06-2008, 11:13 PM   #8 (permalink)
^^ the TDO5 20G will be the turbo I go with when I build a 2.5 for my car.
Online
Old 02-06-2008, 11:56 PM   #9 (permalink)
Thanks Nagy, from reading, researching, and hearing it talked about so much, it has good spool, and good top end, and all streetable. But if he doesnt want that much power maybe just a quick 16 setup would be good.
Old 02-07-2008, 07:08 AM   #10 (permalink)
Thanks guys, originally I thought of the 20g, but changing everything out is a pain but may be worth it in the end. All that needs to be changed at first is the fuel pump, injectors and fuel rails ? Anything else ?
Old 02-07-2008, 07:16 AM   #11 (permalink)
Pump and injectors. The rails do not need to be changed. The pump is easy. You can do that in about 30 minutes. The only hard thing about the injectors is the brackets that hold them on the motor. Not too difficult. I would also recommend at least a big TMIC if not a FMIC for a 20g.
